Question about Garden
Crafsman riding lawn mower model # 944,606951
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
freetek
  • 5568 Answers
SOURCE: how do i route the drive belts on my murray riding
You can download a manual for your Murray here:
Murray manual
This is in .pdf format so you must have Adobe Reader or equivalent available.
FYI: Murray remnants have been bought by Briggs & Stratton so engine parts are no problem, everything else is sketchy.
Posted on Aug 25, 2009
  • 35 Answers
SOURCE: i need an owners manual for a murray riding mower.
First off, confirm that the tractor is in Neutral and the deck is not engaged. You also need to be on the seat, and in some cases your foot must be on the brake. Then try it.
If by "jump" you mean essentially connect one end of a jumper cable to the battery power coming to the solenoid, and the other end of the SAME jumper cable to the 6 gauge (+/-) wire on the other side of the solenoid that goes to the starter, and it cranks, this means one of two things.
More than likely it is the solenoid that is bad, but the only way to confirm this is to make certain that when you turn the key, it sends power to the small (18 gauge) wire on the solenoid. This is easy to check with a test light.
If power is goes to the solenoid when the key is turned, but the engine fails to crank then the solenoid is bad.
If no power is there, then the problem has something to do with either the ignition switch or ignition wiring, or more likely it is a failure of one of the safety switches, under the seat, transmission in gear, sometimes if the deck is engaged, or other.
One way to confirm that the problem is with a safety switch or ignition switch and rule out the solenoid would be to jump a wire directly from the positive terminal to the small wire on the solenoid that comes from the ignition. If this causes the engine to crank, then the solenoid is OK.
Posted on May 09, 2010
I need a dyagram for the mower deck of a 42in cut 14.5 hp crafsman riding mower
my craftsman has a diagram on the bottom of the foot rest look under the mower
May 04, 2012 | Craftsman Garden
I have a brand new Crafsman 22" Rear Bag Front Propelled High Wheel Lawn Mower with a key start. It worked fine for about 20 minutes but then would not turn off once the power lever was released. It just...
It sounds as if the connector for the handle harness became disconnected. Check the wiring connectors and see if one of them came apart. (including the switch...) If it is not that simple please provide a model number and I will dig in the manuals to do what I can do to help you.
Thanks for using FixYa.
Kelly
May 30, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
We need a diagram for a crafsman lawn mwer carb model # 917.372810...whee can we get one?
Go to www.searspartsdirect.com you can get a blow up of the carb by typing in the model #.
Jul 12, 2009 | Garden
Need a diagram for an old crafsman 17.5 hp deck mower belt. can not figure out how to get back on 46" belt
Hello:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
May 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Crafsman #91725850 riding mower wont start
try jumping across selanoid and see if it cranks if it does not you need a new selanoid if it does u might have to change the ground wire or change where the ground wire hooks up to the frame my not have a good ground
Apr 17, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" 19.5hp B&S Stalling
i have a crafsman mower and it only cranks it wont start wat would be wrong
Jan 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Transmission won't engage
My Craftsman 24 hp twin 42in cut motor runs ok as well as the lawn mower. However will not move forward or backwards something is not connecting.
Sep 21, 2008 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
