Question about Refrigerators
Ge profile psc23mg
My ge side by side profile arctica model number psc23mg leaks water on my floor about twice a week. The water puddles in front of the fridge and to the left.
jumptrout51
  • 3361 Answers
SOURCE: My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
Posted on Apr 08, 2009
  • 401 Answers
SOURCE: water on floor under freezer side csx20ea model
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Posted on Jan 06, 2010
SOURCE: GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
walterkunesk
  • 683 Answers
SOURCE: GE Profile side by side
it sound like the drain pan and the drain line need cleaned or maybe the drain tube got knocked out of the pan, take a light and look and see what you find down there and let me know.
Posted on Feb 21, 2011
jumptrout51
  • 3361 Answers
SOURCE: GE Profile Arctica PS123NGMD. Leaks
The defrost drain line in the freezer is stopped up.
You will have to remove all food and turn the refrigerator off for 24 hours to let the drain line defrost.
Posted on Jul 17, 2011
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
Leaking water from the front right side.
check drain tube and drain pan on bottom of unit most likely plugged drain or water line going up door is leaking
Dec 21, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
Good luck! :)
Vlad
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE SIDE BY SIDE FREEZER LEAKS
There is a fix and I have seen it done. Yes GE will not pay for this but if you are willing to spend the time to do a few things to keep it from freezing. Appliance Parts and Repair just below your link and myself can point you in the right direction on how to repair your defrost drain entrance from freezing over. Thanks, Sea Breeze
Jun 16, 2009 | GE Profile Arctica Stainless Steel Top...
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
