Question about GE JES1142SJ Microwave Oven
Doesn't beep after food is done - GE JES1142SJ Microwave Oven
Why does it display 'Food' and beeps when press 4,5, or 6?
Google (GE)(model)(manual) without parens of course to get the manual you need
Dec 15, 2015 | GE Microwave Ovens
How do i disable the beeper
Hello Friend, thank you for allowing me to assist you!
I see that your question is listed under Frigidaire microwave FFCE2238LW. Typically you will hear a series of beep once your food is done heating or defrosting has finished. For this purpose, the beeping signal cannot be deactivated and I show that the volume is not adjustable for your model. Most microwaves are preset to do this. Best regards! - Z
Aug 26, 2014 | Frigidaire FFCE2238LW Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
My GE Microwave Oven won't let me change the Power Level. It is on 10 and takes forever to warm up food. It is supposed to default to Hi but doesn't. I followed the directions for changing the...
There is a solid state switching device called a triac "electronic voltage controller" that has malfunctioned, it controls the power level settings when making power selection, It will need to be replaced to correct the problem. This repair should be done by a qualified technician because dangerous high voltages are present.
Jun 07, 2011 | Microwave Ovens
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
How do I stop the beep when food is ready (it beeps if you don't remove at the food after intervals)? Sharp R-340
I too have Sharp microwave that constantly beeps at approximately one minute intervals if the food you have been heating isn't removed. It is loud, persistent and extremely annoying. I've opened the machine to try and find the loud speaker but cannot find it (it could be built in to the circuitry?). Any help on this would be appreciated. It's a very unfortunate design flaw on what is otherwise a very good and easy to use microwave.
Jun 10, 2010 | Sharp R-340 Microwave Oven
GE Profile Spacemaker II Microwave won't beep
hi,
The control board may need to be replaced, check your records to see if the unit is still in warranty, if it is call for repair. If it's not and you’re handy, you can find the part online and replace it yourself, just make sure you unplug it before you work on it. Please contact me if you need help.
Mar 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
Feb 28, 2007 | GE JVM1660 Microwave Oven
GE JES1142SJ Microwave Oven Logo
15 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
