Question about Epson WorkForce WF-2540 All-in-One Inkjet Printer
How can I use my epson wf2540 fax machine without having a phone connected to it
I can't connected my time warner arris modem to the printer because the technician connected it to the cable box which is in another room.My question is can I fax using some kind of telephone software? I am using Vista OS. Thanks
SOURCE: Mac OS 10.5 Leopard
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard.  Here's what I did.  Go to System Preferences.  Select Print & Fax.  Select the "+" box on the lower left part of the screen.  Select Epson Printer  -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD.  If it does, great.  You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work.  Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner.  I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly.  Good luck.
Posted on Nov 10, 2007
ohms
  • 1879 Answers
SOURCE: Epson LX-300 driver for use in Mac OS 9 and Mac OSX
try using "EPSON Generic 9-pin driver" on the MAC
Posted on Jan 24, 2008
totoman
  • 48 Answers
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..."
After you click ok on the message, you will get another window where you will find a "manual print" button. Click on this manual print button and this will take you to the next window where you have to select "A4 as the paper size" and "CD/DVD as the paper type and paper path" . After this, click print... it should start to print! This is just a workaround until epson gets a patch for leopard for print cd........hopefully
Posted on Sep 05, 2008
SOURCE: TM-U220PD oN WINDOWS VISTA STARTER
Hi, you should try these drivers for Vista...has a preety nice install wizard (works on vista for me).
http://rapidshare.com/files/167170222/TM-http://rapidshare.com/files/167170222/TM-U220.zip.htmlU220.zip.html
good luck
Posted on Nov 25, 2008
ljiohy
  • 31 Answers
SOURCE: Need to Fax from my Computer using an Epson Workforce 600
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a17
Posted on May 22, 2009
Sometimes 3 of the 10 lines have busy signals and dont ring. it is erratic. Sometimes they work and sometimes not. no dial tone.
Did you call to see if all 10 phone ports are registered with the MTA macs on there voip servers?
Have them check your downstream signals, make sure your not losing packets or connection?
Make sure to swap out old phone lines with new phone lines.
Or
the ports on that older Docsis 2.0 modem are going bad and I would suggest getting a Docsis 3.0 Multi - Line Telephony Modem. I would call your provider for best suggested modem.
Hope this helps.
Mar 16, 2016 | Arris Computers & Internet
Bought the same identical modem that time warner provides & had them register it.enabled wireless & rebooted modem. wireless disables when you connect time warner says everything is good on their end
The configuration between the modem and your computer requires digital switching via code settings. Check you manual for the proper communication settings.
Mar 30, 2015 | Arris Computers & Internet
How do I connect A Epson WorkForce 845 to NBN & Telephone
If your phone is provided by broadband then it is now a VoIP phone. In order to use your machine, you will need a fax gateway or a digital to analog converter. This will allow your fax machine with uses a analog line to connect to a digital VoIP line. You will need to connect your nbn provider.
Sep 05, 2014 | Epson WorkForce 845 Wireless All-in-One...
Can't connect to internet through router wired or wirelessly Belkin N750 F9K1103 after ISP dropped out for one hour
Unplug the ISP modem completely, power, and cable. There might be a recycle (a quick push) on the modem as well. Some modems have a battery backup and will stay lit, if not connect the power, reboot and then connect the cable. The modem may take a while to fully reload after reconnecting. Then do the same with the router. Only do a quick push. Holding it in will clear custom settings on the router.
You should have green on both the modem and the router now. If not you have this to inform the ISP of your troubleshooting. GL
Jan 30, 2013 | Computers & Internet
I have a Arris Modem from time warner cable, no i
do you have dsl filter where the phone line comes out of the wall and goes into the Router.
https://en.wikipedia.org/wiki/DSL_filter
Mar 26, 2017 | 2wire (1000-000057-000) Modem
My Epson bx300f cannot send faxes, just says no dial tone?!!!
ALL fax machines are ANALOG devices and will not work on a DIGITAL PHONE LINE.
Jul 06, 2009 | Epson Stylus Multifunction Printer/...
All in one printer for Time warner phone line
ALL fax machines are ANALOG and will not work on a DIGITAL phone line. The new trend now is scan-to-email
Feb 19, 2009 | Epson Stylus CX7800 Color Flatbed...
My epson cx9400 fax states that i need a DSL filter in order to use my fax, as I have Time Warner telephone service which is digital. I would like to know where I may obtain this filter, as I have checked...
You already have the filter if you have both phone and internet on the same line. The installer placed the filter between the lines the phones connect to and the outside line the computer connects to. Just connect the fax line to any working phone jack.
Dec 27, 2008 | Office Equipment & Supplies
Setting up fax with modem
try to used the two conductor cable that came with the printer itself.
- at the same time ask for a filter from your phone provider
- the printer should be direclty connected to the phone walljack
- if you have all this kind of set-up you will be able to recieved faxes now..
send comment/feedback fo furthere troubleshooting...
Aug 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Arris Modem connected to Mediacom Service
I didn't have incoming calls for a year (didn't mind, no telemarketers). But I fixed today.
Check with your home alarm company. Turns out they can download a signal. No, it wasn't the computer's internal modem, it wasn't the phone/cable company or the arris modem.
No need for service call.
Jul 13, 2008 | Arris Touchstone 450a (CM450) Modem
Epson WorkForce WF-2540 All-in-One Inkjet Printer Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
