Question about Sharp (SHRAM900) All-In-One Laser Printer
Error in sharp am900
I've just bought a sharp am-900 but after i setted all the parts and toner. I plugged up and there's a message ERR. SYSTEM [P7] cant get rid of it... cant do anything with the printer... help pls.
  • 1 more comment
  • mfam Mar 10, 2008
    "Scanner Lock" and "PLS return Power" comments keep flashing in LCD; despite numerous re-boots and plug/unplug attempts and checks for jams will change/clear this status.
  • Anonymous May 11, 2008
    error 7???
  • Anonymous May 17, 2008
    ERROR P7
Hi, I just experienced the same problem and realize the reason my msg of "CHK SCANNER LOCK/PLS RETURN POWER" was because I had to many things plugged in the same power outlet (computer, tv, printer, internet)... when i turned off the tv (the machine worked fine). hope this helps
Posted on Oct 06, 2008
  • 417 Answers
I suggest to return it to the store as you have just brought it possible that the scanner lock is still in the lock position but more likely to be a major fault with the machine.
Thanks J
Posted on Feb 17, 2008
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
My AM 900 printer will not print. It will scan. When I click Properties, it always shown offline. Is this a problem? If so, how do I correct it>
The "offline" indication means your computer is having a communication error. There are a few things you can do to troubleshoot this. First, turn your PC and your printer off. Then check the USB cable running from your printer to your PC to make sure it is plugged in all the way on both ends. Power your PC and printer back on. If this doesn't work, try plugging the USB cable into a different USB port. If this doesn't work, uninstall the driver, then reinstall it. If it still does not work, don't rate me yet. Shoot me some more details because I have more TIPS up my sleeve.
Jan 06, 2009 | Sharp SHP AM900 multifunction Printer
Print labels
Have you put the blank labels in the bypass tray?
If you have, the unit is not seeing the media in the bypass tray
Aug 12, 2008 | Sharp SHP AM900 multifunction Printer
Printer am 900
Remove the driver, button manager and sharpdesk then reinstall. Be sure to unplugged the usb connector from pc. After the installation step ask you to connect the usb or restart the pc, plug it.
Jun 11, 2008 | Sharp SHP AM900 multifunction Printer
Cd stuck err 0306 message
Since the cds are stuck inside, you need to open the unit and remove them. There are four screws on the top cover. Remove them (2 on each side) and lift the cover. You should see the cds, remove them, then plug on the unit.
Jun 09, 2008 | Sharp Multi-System Mini Component System...
Sharp (SHRAM900) All-In-One Laser Printer Logo
311 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
