Question about Primo Drip Pan Rack for Primo Oval Junior Charcoal Grill
Rt486g replacement drip pan
In need of wolf drip pan for 6 burner gas range
Why does my 2nd smaller wolf oven smell like gas on start up
without physically being there with a gas sniffer , we could never guess . call a local gas repair service
Dec 08, 2016 | Kitchen Ranges
Nearly brand new wolf range ignitor not working
The cleaner most likely got soap or debri in the gas orifice, this is where the gas goes into the the burner cap. If you can see a spark/light then the ignitors are working properly, just not getting fuel to the area. Pull the burner cap off, check area for particles on/in bruner. Take a twist tie and strip the outer covering off, Use it to clean out the orifice for the gas. Burner ring has an area where the gas comes in. Ensure it too is free of any debri.
Apr 22, 2013 | Wolf Range Kitchen Ranges
Whenever i light the gas top wolf range, the ignighters on other burners keep firing
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module.
I hope this helps you to repair the problem with you stove,
Gene
Aug 11, 2011 | Wolf Range fs-0-27-ft36 Gas Kitchen Range
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Have a Wolf Range Model A-6-9 half the burneres don't light.
I have the same model Wolf Range and need 2 of the Robertshaw SM4 spark modules for it. Robertshaw says they are discontnued. Where can I locate 2 spark modules?
Jul 10, 2009 | Wolf Range Kitchen Ranges
Drip pan
I don't have a solution, but I am trying to figure out how to remove the sealed burner drip pans on a Thermador PRSG 364 GLS gas stove. Any suggestions?
Apr 29, 2008 | Thermador RDFS30 Dual Fuel (Electric and...
Older 6 burner wolf commercial range ignition problem.
If it were the gas regulator, existing flames would go down as more burners are turned on.
There are set screws on the pilot fittings that come out of the manifold, you could try turning those Counter-clockwise to turn the pilots up. (Don't loosen them all the way, they will fall out!) If that doesn't work chances are the pilot stems will have to be replaced to get a higher pilot flame.
Mar 07, 2008 | Wolf Range CHR-10-229-FT11 Kitchen Range
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Primo Drip Pan Rack for Primo Oval Junior Charcoal Grill Logo
Top Primo Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Primo Grilling Expert? Answer questions, earn points and help others
