Question about Husqvarna Garden
Mahindra tractor diagnostics
I have a Husquarvana YTH150 Riding Lawnmower with a 42" deck. Not when I have blades on, but when I release the brake I hear a roaring sound coming from the lower shaft of the motor that drives the rear end. Don't understand, mower still moves like it should & doesn't make noise w/ just the blades on...only hear noise when I release brake, but only thing clutch driven is the blades???????
    Novelist:
  • 212 Answers
You are going to have to disconnect belt and try to turn pulleys on drive system to locate the excact location. It sounds like a belt tension or bearing problem to me.
Posted on Jul 22, 2013
  • 109 Answers
SOURCE: lawn tractor won't stay running if clutch is released.
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Posted on May 03, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
bbreton
  • 437 Answers
SOURCE: tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Posted on Sep 28, 2009
  • 474 Answers
SOURCE: Blades slow down when cutting deck is lowered.
the lowerer the deck the more your working the mower. either mow more often or reduce speed
Posted on Oct 22, 2009
waynepwelker
  • 25 Answers
SOURCE: I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Posted on Jun 27, 2012
Why won't my riding lawnmower shift into reverse?
Some mowers will not allow you to shift into reverse with the blades engaged for safety reasons. Try disengaging the blades then shift into reverse.
Aug 22, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Idles fine, shuts down when release brake.
It could be the brake switch bad, if this model came with one. When it is depressed it will start, but when it is released it may not be switching to stay running.
Mar 27, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Tractor starts, stalls when blade is engaged, or brake released
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I have a craftsman riding lawnmower and the blade engagement is not starting the blades when i lift it. It feels loose when i lift it.
Sounds like you PTO cable is broken. Part # 175067. It goes from the lever on the dash down to a deck mount and hooks to the idler pulley. When you lift the lever, it should pull the pulley and idler arm towards the rear of the deck to tighten the belt to engage the blades.
Jul 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How does the brake spring on 42" deck go back on?
brake spring on the deck to stop the pulleys from turning after disengaging the blades or the actual brake
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
116 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
