Question about Hitachi 51F59 51" HDTV Projection Television
Projection tv issue
Have a crosley projection tv and my son was playing the wii on it. after about 30 minutes of playing the tv made a sound like a surge protector turning off or a curcuit breaker popping. I can access the menu and it looks normal(has red green and blue colors).When you change the channel you can see static. Have cable plugged in and rcas plugged in and the tv does not seem to detect them.
    New Friend:
First open the tv cover and chek the wire on main board connect the same other wise replace
Posted on Jul 19, 2013
ctf1800
  • 4402 Answers
SOURCE: hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
mrlobsterbob
  • 22 Answers
SOURCE: Color Problems with Hitachi projection screen television
check the bulbs
Posted on Oct 20, 2008
  • 41 Answers
SOURCE: the Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Posted on Apr 16, 2009
fillmore85
  • 62 Answers
SOURCE: GREEN color problem in 53" 53UWX10BA Hitachi Projection TV
So is the green color on the screen bowed an equal amount across the screen or does it get worse toward the edges? It may be a convergence problem, but let me know what you see.
Posted on Jun 23, 2009
SD Tech
  • 14553 Answers
SOURCE: hitachi 51f500a rear projection tv screen looks 3d
This model uses two convergence IC's----if 3 D one or both are bad.
Most of the time this set uses either two of the STK-392-110 OR THE STK-392-150 CHIPS.
Both chips and any bad protection resistors around them need to be replaced and the set adjusted.
If you are able to do the repair yourself total parts cost will be under 30 dollars.
Some history for you:
This set like all rear projection tube type sets uses two chips---the ones in your set are Black in color--about 2 1/2 inches wide X 1 1/2 inches tall and are on either one large or two smaller heat sinks with fins on them.
When the chips are installed a white grease called heat sink compound is applied to the metal back of each---the grease transfers heat from the chip quickly to the metal it is bolted to.
After some years the grease dries out from the heat and one of the chips goes instantly.
You can buy a pair of the chips for your set on Ebay for less than 15 dollars plus shipping--
If you cannot do the repair yourself--shop around your area---most shops charge 300-400 for this type of repair. Whoever you get to do it make sure BOTH chips are replaced or you will have the same problem in a few months.
If you open the set and locate the chips---they will have the full STK number printed on them in white letters----there are about 12 resistors around them that need to be looked at--if any are discolored they need to be replaced.
If a shop says it HAS TO GO TO THE SHOP keep looking as any good tech can do this repair right in your home in about 1 hour---I know as I have done hundreds of them.
IF you can solder and are handy I will give you general instructions on how to do the repair and what you need---some people I talk to can either do it or have a friend who can do it for them---let me know
I can tell you what you will need aside from the parts and how to proceed with the fix---
If all this helped rate this solution---I do this here for free.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE LET ME KNOW--I am here to help people.
Regards, SD TECH
Posted on Oct 30, 2009
Testimonial: "You truly are an expert! Thanks for the advice, don't think it could've been explained any better!"
Why is there no sound when I use nintendo on my Sanyo tv?
Nintendo64 Sound ' Nintendo Tech Forums
techforums.nintendo.com > ... > Discussions
Jan 30, 2013 - 6 posts - ‎2 authors
I have recently started playing my SNES and 64. I am playing ... However, when trying the 64 I get picture but no sound. I am using an ... I hooked the 64 up to a Sanyo tvusing the adapter and it worked just fine. My Samsung ... Connecting NES & SNES To A Modern Flat Screen TV ...
Jul 10, 2014
Nintendo 64 on Samsung Smart TV -... ' Nintendo ...
Dec 19, 2012
Wii U not Outputting to TV ' Nintendo Tech Forums
Nov 17, 2012
How to connect Wii to Sanyo Tv? ' Nintendo Tech Forums
May 29, 2012
More results from techforums.nintendo.com
Sanyo HDMI issue - Forums - CNET
Jan 13, 2016 | Sanyo Televison & Video
Wii will not turn on and game will not play or eject
It can be related to a number of issues and so you need to start with checking the power to the unit. Reset the unit if there is power, remove power for about 30 minutes and check again before you need to find help from the service center.
Nov 06, 2011 | Nintendo Wii Console
We have a denon avr-589 5.1 system. It worked great until my son tried to hookup the wii into it. We now have no sound on the tv and dvd player. He normally plays the wii through the samsung flat screen...
foxtile,
How funny my son just did the same yesterday!
Make sure that the speaker selectors and the input modes are set correctly. He must have hit both buttons at the same time which turned off the speaker outputs and changed the input mode to a setup we were not using.
-Chris
Jan 09, 2011 | Audio Players & Recorders
Is there any problems with playing Nintendo Wii with the projection Tv?
it can be the projection tv doesnt work with the wii console change the projection tv for other one
Jan 04, 2010 | Mitsubishi WS-55511 55" Rear Projection...
SCREEN PROTECTOR BROKEN
actually replace the same type with serial numbers.
Jun 15, 2009 | Philips 55PW9363 55" Rear Projection...
My big screen is about 6 to 7 years old and my son wants to use his Wii on it will that be safe. The tv is in our basement and not used very often but I want to make sure it will not ruin the tv???
hi thanks for using fixya!
There will be no problem if your son will use your tv to play his Wii. Just make sure that all the connections from Wii to tv are all in proper connections and you have a good ventilation as well.
regards!
May 05, 2009 | Hitachi 51F59 51" HDTV Projection...
Akai 54' projection tv picture no sound
U obviously don't have all ur sund cables connected right or if ur running it through ur sound system put it on phono
Mar 05, 2009 | Akai PTH5498 54" Rear Projection...
Wont turn on green light comes on then shuts right off
Wii is compatible with all projection TV, try lowering down resolution settings on Nintendo and check PAL/NTFS settings.
Jan 09, 2009 | Proscan PS35660 TV
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Hitachi 51F59 51" HDTV Projection Television Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
