Question about Hilti Pd32
When I turn the hilt pd32 on,it just beeps. I can not clear the previous setting or take a new measurement. The batteries are new.
Leica disto classic 5a
the only thing which comes to my mind is that
the laser may have become weak ....
did u try with new batteries..
ne way the new ones also cant measure more than 200 m...
the device might be loosing its strength..(maybe that guy had used quite a few times)
Oct 22, 2008 | Leica DISTO A5 Rangefinder
Lenovo desktop 3282 beeps twice then 5 times and goes no further
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 01, 2012 | Lenovo Computers & Internet
I just put new batteries in my Omron HEM-780. Doesn't work. When it finishes deflating it always says E7. What's going on?
Hi library336
The Omron HEM-780 generally has 5 Error Messages:
1]
ERROR MESSAGE: A single (E) Error message indicates movement during the measurement process, resulting in an inconclusive reading or the absence of a Blood Pressure or Pulse reading caused by a weak Arterial Pulse.
SOLUTION: Remove the cuff. Wait 10-15 minutes. Repeat measurement using approximately 40mmHg more pressure than in the previous measurement.
2]
ERROR MESSAGE: A Double (EE) Error message indicates an under-inflated cuff. Remove the cuff. Wait 2-3 minutes.
SOLUTION: Repeat measurement using approximately 40mmHg more pressure than in the previous, under-inflated measurement.
3]
ERROR MESSAGE: An E directly below another E Error message indicates an over-inflated cuff (in excess of 300 mmHg). Remove the cuff.
SOLUTION: Wait 2-3 minutes. Repeat measurement using approximately less pressure than in the previous, over-inflated measurement.
4]
ERROR: A Blank Screen indicates low or depleted batteries.
SOLUTION: Remove and replace all 4 AA Batteries. Do not mix used and new batteries.
5]
ERROR MESSAGE: An (Er) Error Message indicates an abnormal memory function caused by a faulty internal component.
SOLUTION: Call Omron Customer Service, Toll Free, on (in the USA) 1-800-634-4850 (or on the equivalent Toll Free or Freefone Number in your country).
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 15, 2011 | Omron Health & Beauty
My pc wont turn on before that happend i heared 9 beeps and turned off. So now it dosent turn on please help me !!!
find the cmos battery of you computer.replace it with a new battery.. then reset your cmos or clear your cmos using the jumper. enter to your bios set up.other use DEL,F1 or F2.. then load default setting. save and exit enter to confirm..
Jul 06, 2011 | Dell Dimension 2400 PC Desktop
Problem with the Intel Desktop Board DG41BI\r\n I
setting the memory is pointless as the system will automatically find the best speed for it if its set to auto. As for the 3 beeps that is generally vga, but could be different on this motherboard , when you clear the bios do you move or short a jumper
Mar 11, 2011 | Intel Motherboard
My scooter has a code 31 that says has to be cleared before it will run. we were gone for several months, whe nI came home we charged it up but won't start has a code 31. Book says it has to be cleared to...
Sounds like you need new batteries. This code indicates a low battery condition.
If you have a digital voltmeter measure the voltage of each battery. Above 13 volts is best, 12 volts indicates a 50% charge. The total voltage when you add the two batteries together needs to be above 17 volts for the electronics to work.
Batteries that sit for several months may not take a charge. You can try charging them separately with a car charger set to gel/deep cycle setting to bring the voltage up. Make sure they are disconnected from the scooter and do this only for a short time, keeping your eye on them. The batteries may be too old and the plates sulfated by sitting too long.
A new set of U-1 batteries is my best recommendation. They are available locally and on line at a discount. If you install them your self you could save over $100 on the labor cost alone.
To clear the code install the new batteries and turn the scooter off and on. The code will clear itself when you disconnect the batteries. Charge the new batteries fully before use. Hope this helps.
Dec 08, 2010 | Pride Mobility Victory 3 Wheel Electric...
Wheelwriter gives 3 beeps when turned on. Meaning?
Try this. Remove the batteries, turn off for 30 sec. turn back on.
This will set everything to default settings. IT WILL ALSO CLEAR THE MEMORY!!!
DickyO
Mar 19, 2010 | IBM Wheelwriter 30 Typewriter
Head unit beeps in my boat.
It is a low voltage warning beep. They will beep even with the slightest voltage dip. Very annoying. You may be able to go into the set up menu and turn it off or lower the volume of the beep.
May 01, 2017 | Rockford Fosgate Car Audio & Video
Continous Beeping sound
Hi neosw,
Could you provide a little more detail?
Was this a previously working set-up or is this a new build?
If this was a previously working set-up have you changed anything?
When you switch on the PC
  • do you see anything on the screen, does the monitor remain in standby?
  • are any of the fans running?
  • does the hard drive spin up?
  • does the beeping sound stop after a short while?
The reason I ask these questions is because a continues beeping usually means that the BIOS is not seeing the processor, or that the power to the processor is not correct. With some BIOS manufactures it can also mean the processor clock speed is not set
correctly.
Please don't take this the wrong way but...if you provide greater detail in your question, the easier it for us to diagnose your problem, otherwise we can only make educated guesses.
I hope this has been of some help.
Regards,
Spare head 2
Jan 06, 2008 | Soltek SL-K8AN2E (SL-K8AN2E-GR)...
Hilti Pd32 Logo
Top Hilti Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Hilti Measuring Tool and Sensor Expert? Answer questions, earn points and help others
