Question about Lionel 1122 Right Hand O27 Remote Control Track Switch
How to connect lionel 1122 switch to constant voltage on transformer
I want to supply constant 14 volts from transformer to 1122 switch. How is the connection made and what if any modifications must be made to switch wiring itself? Thanks. Steveflash
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: I have a Multicontrol 115 volt transformer (4
I went to a train dealer.
Posted on Nov 21, 2009
heatman101
  • 43501 Answers
SOURCE: Lionel trains a/c transformer is
You are hearing the primary hum but the secondary is either burnt out or there is a fuse that is blown...
Check for fuses and/or circuit breaker...
Also you can OHM out the coils to see if you get continuity through each coil...coil open equals no good...
heatman101
Posted on Dec 13, 2010
ErusTownsend
  • 592 Answers
SOURCE: I have a lionel ZW
first you need to test the actual transformer's input then the outputs on primary and secondary winding. Be careful because you can get a schok. If you do not know what you are doing with electricity and don't understand how to test transformers then you should consult an electronic service center to help with this procedure.
Here is a guide to test transformers. http://www.infobarrel.com/How_to_Test_DC_Voltage_Using_a_Multimeter
Since this is a train control there is a potentiometer in it (variable resistor) you will want to check that as well.
In the end the best and cheapest route is look for a replacement one.
Posted on Jan 30, 2011
  • 4 Answers
SOURCE: Can I use the cw-80 transformer on any Lionel
You should be able to. The Lionel transformers all put out AC power, not DC and many Marx and American Flyer transformers will work too. The real question is total amount of power being drawn and whether or not you have the wattage to match your engine and accessories. With the CW-80 though, it should put out plenty. I run my pre-war 1666E engine pulling a full compliment of metal cars with no problems using a CW-80.
Posted on Feb 10, 2011
Want to use this on 220v aussie supply to power 1947 221 lionel train loco Suitable?
ohh no that id not try at all , one can first use a power converter that one can buy off many online sources to convert 220 volt down to 110 volt then to transformer this will be safe 4 unit, the 50HZ to 60 Hz doesn't matter to much as well unless one plans on using the lionel sound generator , then its not gonna sound to spry as it will be a bit slower !!
Jun 16, 2015 | Lionel O Train Transformer 6-14198
I have a new heater with diferant terminals from the old one so not sure how to atach the wires
There is no need to rewire the internal of the heater!
Just bring in the electrical supply to the heater, it can be either 120 or 240 volts.
If the heater you have is like the picture associated with your post, then all then have to do is change the supplied plug from 240 to 120. It comes pre set for 240. That plug is inside the cabinet.
If any other brand, then you need to change the wires at the transformer of the heater. All heaters need to be supplied with primary voltage: 120 or 240. Then the control system is supplied with secondary voltage out of the transformer. The secondary voltage is no more than 28 volts. and these wires are normally colored as blue or yellow.
Secondary power is already wired within the heater. NO need to change where they are. You will only need to deal with the Primary wiring.
There are many varieties of transformers that transform high primary voltage to a low secondary voltage of 28 volts. and these transformers have many wires: primary & secondary.
I will try to make this easy to understand.
If you have a Gas Heater Transformer with these colors:
  • Red
  • Black
  • White
  • Green
Or...
  • Red
  • White with Red Stripe
  • Black
  • White with Black Stripe
  • Green
These are Dual Voltage Transformers, you can bring in either 120 Volts or 240 Volts
If you bring in only 120 Volts...
1st example:
The Red wire will not be used! Hot wire to the Black, and the Neutral/Common, to the white wire. Green to ground.
2nd example:
Connect the Red wire with the White with Red Stripe together and connect these to the incoming Neutral/Common wire, normally White.
Connect the Black Wire with the White with Black Stripe to your incoming Hot Wire, which is normally Black.
Green to ground
If you bring in 240 Volts...
1st example.
1 Hot wire to the Red, the Other Hot wire to the Black, and White wire is not used. Green to ground
2nd Example:
Wire nut the two Striped wires together. then one incoming Hot wire to the Black, the other incoming Hot wire to Red.
Green to ground
Or This is only a Low voltage - 120 Volts Only
  • Black
  • White
  • Green
Or either any of these combinations...
  • 2 Blacks w/Green
  • 2 Reds w/Green
  • 1 Black, 1 Red w/green
This type will only be a high voltage, 240 volts only
Picture below is what a transformer looks like and it is where your incoming supply wires go. The smaller leads with the spade connections will go to a specific location & is the 'Secondary" .
Good Luck
Mar 14, 2015 | Pool & Spa
My 1941 Lionel train stops getting enough power to run all the way around the track. Voltmeter says 15 volts around all track and transformer says 15 volts. How do I test engine?
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Dec 16, 2013 | Lionel Trains Classic Freight Train Set
Wiring 1122 switches for crossover
Question is unclear. But if you want both switches to throw at the same time all you need to do is connect the 3 terminals on one switch with the matching terminals on the other switch. Run a wire from left to left, center to center and right to right. If the switches do not switch into the same track just reverse the right and left wires on one of the switches.
Nov 27, 2013 | Lionel 40 Watt Transformer Train Set Track...
Lionel cw-80 transformer blown voltage regulator i cant read the size can you help?
The voltage regulator is part LM78L05. You might want to check the two diodes are ok as well 'D1' & 'D2', sadly I can't see markings on them.
Dec 19, 2012 | Lionel Cw 80 Transformer
Will it be okay to connect a 110 volt laptop to a 220 volt LCD projector?
What voltage is your mains supply?
The laptop's adapter should be a multi-voltage type 110 to 240 volts input.
If your mains is 110 volts AC then the 220 volt AC LCD projector won't work unless you connect it to a step up transformer (110 to 220 volt transformer).
If your mains supply is 220 or 240 volts then both the laptop and the LCD projector will work without any problems.
Aug 24, 2010 | Computers & Internet
Hello i have a Sony Vaio PCW-W2 that i brought to canada from uk. how do i switch voltage to 110?
u can find voltage converter connectors......try using that....u can ask for travel adapters....hope u find them
Mar 08, 2010 | Sony Computers & Internet
I am trying to hook up a Lionel 1033 transformer to my Christmas train. What terminal goes to what? I want my old 2026 to smoke and my 6446W to whistle.
I have the original Instructions for Operating the 1033(written in 1953) - the second paragraph of the "How To Connect Transformer" reads as follows: The "Multi -Control" transformers listed in this leaflet have four binding posts located on the top of the transformers. Of these, "A-U" and "B-U" combinations furnish variable voltage for the track. The control arm of the transformer simultaneously regulate the voltage output of both the "A-U" and the "B-U" combinations. The transformer nameplate indicates the voltage ranges of these two combinations.The "A-U" combination supplies any voltage from 5 to 16 volts. The B-U combination has voltage from 0 to 11 volts. In selecting the proper range of voltage for your particular outfit, try the lower "B-U" combination first. If the maximum train speed is not satisfactory, then try the "A-U" posts.
To paraphrase the "How to Connect Accessories" section: accessories work best with fixed voltage - these voltages are obtained from the following pairs of output binding posts: "A-B" 5 volts; "B-C" 11 volts and "A-C" 16 volts.
Hope this helps, Mark
Dec 14, 2009 | Toys
How do i wire the transformer? there are four
ther will be four wires but they will ahve all colours
blue black negative red brown for posityve green yellow earth and white may be anothe r earth
any way try and see the colour on the tracks and join appropriate and each wires to them
maybe white and yellow can be joined together
it will not arise any problems by doing so
Sep 27, 2009 | Lionel Trains Classic Freight Train Set
Are the tracks new?
Is the lockon new?
Dec 14, 2008 | Lionel Cw 80 Transformer
Lionel 1122 Right Hand O27 Remote Control Track Switch Logo
70 people viewed this question
Top Lionel Video Game Consoles & Games Experts
James Wishart
Are you a Lionel Video Game Console and Game Expert? Answer questions, earn points and help others
