I have the Amana push button washing machine with automatic lock and the lock broke so I cant use the machine. Model # W10338679C. Is there a fix for this?
if the lid lock is broke it shouldn't be doing anything.
If it is broke, it needs to ne fixed/replaced.
If it is doing other things, more troubleshooting is necessary.
you will need to take the top off and push the drum to the rear to locate the door fixing screws and adjust as necessary and or adjust the door lock eric
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Unplug the machine wait 10 seconds than plug the machine back in and press the cancel/stop button twice. this should unlock you washer and fix the problem. If this does not please give me the model number of your unit. it is located on the inside of the lid of your unit.
