Question about Pool & Spa
How do I replace a Jandy R3001300 Control Assembly
Why jandy lg125p wont light?
see if gas ok replace pilot generator assembly and make sure no cobwebs in tubes
May 25, 2014 | Zodiac Pool Systems Jandy Lite2 LG 125P...
Laars Lite 2 Pool Heater max temperature too low
if hooked to a system increase temp if not try new temp sensor in heater
May 04, 2013 | Jandy Heater Temperature Control Assembly...
Jandy Lite 2 igniter replacement how to
go in through the bottom follow the two white cloth wires either bottom center or right side bottom on burner
Jul 21, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Trying to heat pool . turns on the it will go off and say check ignition control
make sure gas pressure is good see if ignitor is glowing if not replace ignitor
Dec 19, 2010 | Jandy LAARS IGNITION CONTROL ASSEMBLY,...
How to test an ignition assembly board for ld/125 laars lite 2 before replacing it.
this may tell me you dont know if the ignition control is not working. see the owner manual at jandy.com
Aug 26, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
Pool & Spa Logo
26 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
