Question about Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer FFU14FC6C
Button freezer frigidaire reset upright - Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer FFU14FC6C
5 Suggested Answers
  • 9 Answers
SOURCE: freezer only cools to 40 degrees
check to see if there is ice built up on the inside back if there is it may have defrost problems or if part of the back has ice it may be low of freon
Posted on Apr 20, 2009
TheMazz
  • 78 Answers
SOURCE: I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Posted on Oct 13, 2009
  • 523 Answers
SOURCE: 20.3 Cu. Ft. Frost-Free Upright Freezer - White: What could be causing Frigidaire freezer to leak w...
stopped up drain,tear in gasket,not going into defrost soon enough
Posted on May 06, 2010
  • 91 Answers
SOURCE: Upright freezer orange and red
Draw fan has failed, temp unreachable over the past cycle of 24hrs, turn your unit off for 24hrs and defrost it, restart and should work fine for a few days, if so, replace fan and defrost element only. Call service tech for this unless you are clued in on this work, not that costly.
Posted on Aug 28, 2011
My frigidaire freezer upright has an error message door ajar
Sounds like the main control board to the unit needed to be reset and with the resetting it has caused a communication error with the door sensor. Contact a service tech to move forward with a repair.
Sep 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The freezer has digital reset buttons. What do we do to get it to start cooling once it's been unplugged?
dear sir/madam
make plug in on electrical source then find out on/off button on your freezer,s control panel and press it for reset.
i hope after do that your freezer will work .
thank you
Hope answer the question
please vote!
Sep 06, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
CE flashing in the temp window of upright freezer I can silence the alarm by pushing the reset button but the red light blinks. Inside the freezer the indicator means operational error
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 08, 2010 | Frigidaire 16.7 cu. ft. Upright Freezer...
My Frigidaire upright freezer is only 4 years old & isn't working
freezers have safety devices to protect themselves. The compressor has an internal overload to keep it from overheating. some have external reset buttons and some do not. either way the cause must be corrected. if the freezer was low on refrigerant you would see signs of oil near the coils, tubing, or compressor. If there is no leak, it overheats when there is airflow restrictions(dirty coils) or a fan has stopped working. only a few screws keep you from seeing all there is to see. If it is clean and the fan is running, then the compressor may just be the culprit
Nov 24, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
My freezer is stuck in defrost mode causing the alarm light to remain on
My freezer wouldn't run and I did find there was a reset button on the back of the freezer where the chord runs into the switch.
Jun 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer alarm
Upright freezer door was ajar, alarm went off. Where is the reset button? Product is Frigidare.
Jun 02, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer FFU14FC6C Logo
24 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
