Question about Motorola Mobility RAZR V3
My phone is pushing its own buttons
I can't even make a phone call. It's like this..''hi [beep] how are [beep]''.. and its only the number six thats like sticking, because thats what shows up on the phone. Even if i just open my phone it starts hitting the six. Maybe its just busted. Does anyone know if it can be fixed???? (before i just buy a new phone) I tryed everything, including throwing it.
    Brigadier General:
  • 7,752 Answers
You need to have a keypad file reflash into your phone, so take it to a mobile service center and have them reflash it for you.
Posted on Feb 23, 2008
I have a adt simon 2 alarm system which is no longer monitored by adt. I accidently pressed the phone test button twice and now it continually beeps. How can i cancel the phone test, I've tried...
Get the front cover open by pushing the tab at the top of the panel down while pulling on it. When the cover is down enter the 4 digit master code using the red numbered keys. On the left you will fine a small menu that list different "options". You want to turn "option 1 off." To turn off option 1: Hit the delete key then the option button one time for option one finally push the bigger button in the left bottom corner. I think it's labeled enter or something to that effect. You can listen to the prompting of the panel to know exactly which one to push. After that close the front flap and no more beeping will happen. You will still get the siren in the event of an alarm but trouble conditions and entry exit beeps will be no more. I hope that helps!
Jun 19, 2014 | GE Security Simon 3 Wireless Home Security...
My stereo says locked on my chevy cobalt 2010
see this procedure and fix it. God bless you
    • 1 Start the car and turn on the radio.
    • 2 Press down on preset numbers two and three until a three-digit number displays on the radio. Write this number down.
    • 3 Push the AM/FM button and a new three-digit number will display. Write this number down to the right of the original number, to create a new six-digit number.
    • 4 Call 1-800-537-5140. This is the radio code phone line.
    • 5 Enter 106010, and then press #. This is the Chevy radio dealer code.
    • 6 Type in the six-digit number you had at the end of Step 3, and then press *. The phone line will then give you a four-digit number. Write this down.
    • 7 Use the Minute and Hour buttons on the radio to type in this code, and then press the AM/FM button to unlock the radio.
Oct 13, 2012 | Cars & Trucks
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
Jul 02, 2011 | 2003 Pontiac Sunfire
I have a Panasonic KX-T2345 and I need Info on programing memory stations and using "call hunt". Thanks
PanasonicKX-T2345 program buttons
To Program
Push Buttons
1 Memory slide Sw Under
Lower RT lip to Program
2 Memory light lit
3 Station button Press (Beep)
May want to write name 1st
4 Memory light goes out
5 Dial Phone number
6 Memory button Press
(Long Beep)
7 Memory light lit
...repeat 3-7 for more Ph #
8 Memory slide Sw Under
Lower RT lip to Set You are Done
PanasonicKX-T2345
Mar 21, 2011 | Panasonic Lands Phones
All-in-one 4110 hp fax not working
what kind of connection you are using, I ment broadband or some other
Aug 21, 2009 | HP Officejet 4110 All-In-One InkJet...
When i turn my ps3 on nuthin would show up on the tv. You can't even hear anything on the tv...it's just blank. Someone please help me..!!!!!!!!
Alright mate, Try these steps...
1. turn on the ps3 so it is in stanby i.e. the red light is on. 2. push and hold down on the red button for as long as it takes to turn the ps3 back off on to standby, you should hear a beep. 3. when it goes back to standby do the same thing again, and this time you will hear one beep (when you pressed it) and two more beeps and it will go back to standby 4. when it is back in standby again, push and hold down the button again, you'll hear the first beep, then three more beeps, and it will go back to standby. 5. do the same again, however when it turns on this time, if done correctly, it should say connect the controller using a usb cable. do this and turn it on. 6. Go through everything it says on screen, 6 options should eventually appear, for me, option 4 did the trick, but i heard option 3 works too, as the other ones do too i presume. 7. the final part is that it will ask you to restore the hard drive etc... just keep pressing the ok button.
if all fails, then phone this number (sony) 0818 365 065. glad to help. let me know.... David.
Jul 18, 2009 | Sony Playstation 3 (PS3) Console
Cannot record new answer phone message
push the mute button on your cordless uniden phone,and you will see the number 5 come up on the phone display.then hit the number 6 and when you hear it begin to beep record your message
Mar 13, 2008 | Lands Phones
The lid will not lock.
you cant bypass this switch by pushing w/ screwdriver. its a magnetic reed switch open the top deck (3 screws behind the console) inside should be a tech ref sheet quite helpful trouble shoooter in ther
Jan 13, 2008 | Fisher Paykel EcoSmart GWL15
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
