Question about Vacuums
How to open power head of Nutone CT600
Need to change the belt. How do I open the power head
2 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: I have a Broan Nutone
If the power head is spinning when you lift up the handle then the head could be blocked with dirt. You may need to undo the floor head to see if the entire brush roll is clear as well as the main dirt channel/turbine wheel. Ensure that everything is clear before assuming it may be the belt that needs to be replaced.
You may well have to call or contact the main company who makes Broan Nutone models for them to send out / query the power head problem.
Posted on Apr 19, 2008
How do I change the belt
turn the power head upside down. There should be a latch to open. the belt goes from the center of the floor brush to a piston on the motor. It helps if you have the old belt to get the correct size.
Feb 11, 2015 | Vacuums
Change belt
flip it upside down , undo 2 phillips screws, flip top up and off from the back, lift out roller , replace belt , stretch back in place , put top back on starting with front lip, then put in screws
Apr 25, 2013 | Beam Rugmaster Plus Belt
I have a CT600 power brush that would not power up. Thinking the motor was bad in it, I replaced it with a new CT700 power brush, I am still experiencing the same problem the power brush itself does not...
First try connecting the power nozzle directly to the hose. If it works, the problem is due to a broken wire or faulty connection in the wands. At least one wand will need to be replaced.
My guess is it's probably due to a broken or disconnected wire. This could be in the hose (most likely), the wands, or the tank wiring itself. You can test the hose wiring by using a multimeter or continuity tester. A tester may be easier for you to use, and will provide the info needed.
Disconnect both ends of the hose, sit down, and lay the ends on your lap. Touch one end of the probe to a terminal on one end of the hose. Place other probe on a connector at the other end. One connector will light, the other won't. Now repeat with the other terminal at the first end of the hose and repeat. The terminals will read opposite the reading in the first test. If the light fails to turn on with either test, it's a broken wire in the hose. This is most likely near/at the handle end, or at the wall end. In some cases it can be repaired, but not always.
It could also be due to a faulty switch.
For a definite diagnosis, take the unit, the hose, power nozzle etc. to a repair center.
Jan 28, 2011 | Broan-NuTone VX550 Bagged Central System...
My broan cv30 purchased in 1996 carpet power head unit sucks up dirt and rocks but will not pick string or yarns up from carpeting. I find myself picking it up. It is sucking fine dirt and small...
It's possible you simply need a new belt or roller brush. Place the power nozzle upside-down turn the vacuum on. Ensure the brush turns. If it doesn't, the belt has broken or is too worn to turn it. Replace the belt. Make sure the tension is properly set prior to reassembling the power nozzle.
Next, with the power nozzle upside down, run the flat of your palm across the brush area. If you can barely feel the bristles, it needs replaced. A good brush will loosen the yarn and strings, but needs to be cleaned periodically.
As long as the powerhead motor is running, there is no need to replace it. If it's not running, look for a reset button and press it. There could also be a broken wire, loose connection, or bad switch causing a power head motor to not operate..
Dec 31, 2010 | Broan-NuTone Vacuums
See were to put the swr driver on both sides and not sure where to pull up
I'm pretty sure you're asking about a Kenmore canister vacuum,
Here's what you'll need to replace a belt on a Kenmore2_bing.gif canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
There are two different types of belts2_bing.gif that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner2_bing.gif. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking.
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Thank you very much,
Chris J.
GoVacuum
Apr 07, 2010 | Vacuums
Beater brush won't spin when on carpet
You need to change the belt. When it does that it means it is worn. You can get replacement belts for it here:
Central Vacuum Belts
or here is
Broan Central Vacuum Belts
Nov 04, 2009 | Broan-NuTone CV350 Performance Bagged...
How do you open up the power head to check the belt?
Turn the power head over so the bottom is facing up. On the bottom towards the back there are two holes (one on each side) where you can get to the access screws. Remove the two screws (you'll need a phillips screwdriver). With the screws removed you can now remove the top cover from the base by pulling out on the two clips on each side of the power head. With the top cover removed you can get to the belt and roller brush. If you need a belt for this model you can get it here:
http://www.vacbelts.com/20-5218-belt.htm
Oct 22, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Power Unit VX475 Stops
Checked and found that motor is definitely overheating for unknown reason. Since power unit is still under warranty, solution was to contact local service company for NuTone power unit and have them come out and fix/replace it free of charge.
Jun 27, 2008 | Broan-NuTone VX475 Bagged Central System...
I have a broan central vac system need belt for cv315-b vac head cant seem to find one any idea where i can get 1 thanks
I believe that the Broan replacement part number for the belt for the CV-315 power head is a 9967-0585. available through a Broan/Nutone dealer.
May 11, 2008 | Vacuums
I have a Broan Nutone central vacuum. The power head seems to stall unless you lift up on the handle. I think I may need to change the belt but cannot find a place to purchase one to see if this is the...
Apr 19, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
