Question about GE GTS22KBP Top Freezer Refrigerator
Tbx22 i have a 1989 version ge tbx 22r. lately the fresh food box has trouble staying cold, but the freezer sorks fine. i cleaned the coils, but still a problem. i shut if off and let is sit for about 8 hours, and when i plugged it back in, it was great for a few days, then fresh food temp started rising. it seems when that happens, there is very little if any flow through the little air duct into the fresh food box. I also dont see any water in the pan at the floor, nor any water inside the freezer or the fresh food box. Any ideas?? Thanks mborisky@hotmail.com
4 Suggested Answers
SOURCE: GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Posted on Sep 28, 2007
SOURCE: GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Posted on Jan 28, 2009
heatman101
  • 43501 Answers
SOURCE: 48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Posted on Sep 29, 2010
Ge refer model psc25mstass fresh food section not cold enough freezer cooling fine
I realize this is an old post but information is always helpful if it is correct. I have a GE Model TFX22ZRB, Main tools needed are a refridgerator thermometer, a cheap multimeter, 1/4" hex driver, phillip screwdriver and regular blade scewdriver, above all, alow time for tempeture change when measuring tempeture. The freezer is running at -8 degrees C or aproximately 28 degrees F. I don't care about 1 or 2 degrees at this point in the freezer, the defrost system is working ok, The freezer is cold enough. The fresh food section is running at 48 degrees F, the damper is wide open between the freezer and cold food section, I manually removed the damper door and controls since I am only interested in seeing if I can drive the fresh food section colder. Looks like the fresh food thermostate controls the compressor and not the damper to shut off the cooling process when the tempeture gets cold enough. Since the fresh food section does not get cold enough (this should be in the uppers 30s F) there is no need to move the fresh food thermostate out of the normal range setting (mid point in my case) with the operator control. Defrost heaters ok, this unit uses 2 heaters hooked in series with a evaporator coil thermostate also in series with the heaters. Heaters aproximately 25 ohms total risistance, coil thermostate open at room temp and closed when below 32 degrees. Only other item in circuit is the defrost timer, this can be manually advance to open and close the defrost circuit, in my case, when in the defrost mode, the evaporator fan stops and the heaters heat up. The defrost timer in my case has a 12-16 hour cycle time and a 30 min defrost time, so in a 24 hour period I may get only one defrost cycle. One item of importance. make sure something has not fallen in the lower back or the fresh food section of the refridgerator to block the air flow return, this will effect the coo;ing process. Now with the damper wide open, the defrost circuit working ok I am going to look at the evaporator fan itself for speed, shifted blades or the air circulation between the freezer and the fresh food section, I have cleaned the condenser coils but I am leaving the condensor and compressor out of the equation since the freezer is cold enough but at this point I am considering the possibility, I may need to replace the fridge if the compressor is not working to par.
Jul 18, 2012 | Refrigerators
Refrigerator inside not getting cold enough. A GE refrigerator side by side.
If it is just the fresh food section and not the freezer. Check out this link to see a GE condenser problem. Make sure to clean that condenser once a year. In most cases when the damper assembly flapper door goes bad in the fresh food section, the fresh food side will start to freeze your food. The next thing I would check is what John is talking about. Pull the freezer back panel off to see if your evaporator coil is frost over. When this happens it will restrict air into the fresh food side(refrigerator side). Click Here to see what a defrost problem looks like.
Jun 23, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My compressor runs but I think it shuts off and stays off too long...the box gets to warm and the ice starts to melt before it starts again
First of all, before you do anything, clean the coils under the refrigerator. I couldn't tell you how many refrigerators I've 'fixed' that needed nothing more than the coils cleaned. Dirty coils can cause a multitude of problems, many of them with the exact same symptoms that would be expected when refrigerant components fail. Dirt is the #1 enemy of any refrigeration unit.
If that doesn't help, since both sides of the refrigerator get warm before the compressor kicks back on, I'd suspect the fresh food temperature control thermostat. Not an easy fix for the average homeowner unless you've got specific skills in appliance repair.
Before you do anything, try this. Turn the fresh food thermostat all the way up, the set the freezer setting at a higher than normal setting. The way the system works is that the fresh food thermometer turns the compressor on and off and the freezer control simply controls how much of the cold air from the freezer is diverted to the fresh food compartment.
If you turn the fresh food thermostat higher, the compressor will run longer and adjusting the freezer control to a higher setting will allow less cold air into the fresh food compartment, forcing the compressor to run longer in order to cool it to the thermostat setting.
If the settings have to be abnormally high, this is a workaround, rather than a fix. To get a permanent fix, you'll probably have to replace the fresh food control thermostat.
I hope this was helpful to you or to anyone reading it.
Oct 10, 2009 | Amana Refrigerators
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works refrigerator doesn't ge tbx-25zle
Hi: Your defrost heater or defrost timer is bad. There is an off chance your freezer or fresh food compartment are so full they block the airflow. If not full, Remove the food from the freezer, unplug the ref. and hit the back wall of the freezer with a hair dryer. Avoid plastic components as they will melt. When your defrost mechanism fails frost will form where it shouldnt and block the airway to the fresh food compartment. That's why the freezer still works. That will get you a week or two of fresh food getting cold. If your'e handy remove the back panel of the freezer at the bottom will be a glass tube with a metal coil in it. If the coil is broken buy the new defrost heater and install it. If not look for a defrost timer. Use the model number of the refrigerator to find the part. www.searspartsdirect.com will have a parts schematic to help you find out where the timer is located. There shipping is high so try to buy it locally. I hopes this helps, Jeff
Jun 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer Side is fine bit refrigerator side isn't cooling. Vents have been cleaned.
Pretty common problem among refrigerators. Look to see if you have frost on the rear wall of the freezer just above the lower basket. If you see frost on the rear panel, it most likely has about 3 to 4 inches full of frost on the coils behind that panel. If it does, you will have to remove the lower rear panel, and defrost the coils until they are clean, just like it was at the factory new. Once those are cleaned of frost, you should replace the defrost heater at the bottom of those coils. Some GE's have a kit that has a heater and a defrost thermostat all in one, and some do not. Some only come with just a heater replacement. If it comes only with the heater, you must also order a defrost thermostat, which is positioned above the coils, also. They both MUST be changed.
The other thing is to make sure that the fan inside of your freezer is working properly. The fan motor, and the defrost heater assembly are very common problems. Your refrigerator will work fine if you find out frost was the problem here, because the fresh food side gets its cold from the freezer side. If it is plugged with frost, the fan can't push air through the coils to the fresh food side. Hope this helps.
May 21, 2009 | GE GSH25JFR Side by Side Refrigerator
Fresh food side warm. Freezer works fine.
I think you are short of refrigerant, needs to be topped up and checked for leaks.
Mar 03, 2009 | Samsung RS2534 Side by Side Refrigerator
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
GE GTS22KBP Top Freezer Refrigerator Logo
47 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
