Question about Castelle LANpress Jr. MP (66298601-040) Print Server
Castelle lanpress Jr. MP Model name: AS3600
Is there a test to see if this part is working? We are using it in a summagraphics plotter/cutter model T1300. We changed the master circuit board on the summagraphics. We tried switching cables, we also know that the functions on the plotter are also working. Is there a pin connection that we could put a bridge for an LED to show data?
Rabbit HX 720 Vinyl cutter plotter cutting blade will not lower to cut
Since this is a sewing machine category, it is unlikely there will be a good answer.
Aug 31, 2017 | Sewing Machines
What is AppHangXProcB1 in my cutter plotter
What kind of plotter. Reading the error it appears that some process is freezing up. This can be caused by a corrupt print job, bad driver. First step you want to take is to update the firmware on the plotter.
Jul 23, 2016 | Office Equipment & Supplies
Rabbit cutting plotter 420mm
If you have the plotter, what do you need?
Jul 12, 2014 | Computers & Internet
I am facing a problem with my cutter D610 that it was working normal but the next day i do the cutting order and it send the order but the cutter not taking the order.. that i see from the cuttur icon that...
Dear Tarek
1. Check the interface cable try replacing it first.
2. Goto printer and faxes and you will find you cutter driver there double click to open it.
3. Make sure in the file menu the 4th option PAUSE PRINTING is un-ticked.
This should solve the problem.
DO RATE MY SOLUTION
Jun 27, 2011 | Summagraphics SummaSign Pro T610 Printer
I NEED THE DRIVERS FOR MY D500 VINYL CUTTER
http://www.summausa.com/support/software.php
scroll to the buttom of the page for the 3 usb drivers,, PS,, you will also get the software there as well..
Oct 22, 2010 | Summagraphics Office Equipment & Supplies
DesignJet 5500PS InkJet Printer WILL NOT CUT THE
check the media you have selected. if you have the wrong media selected, the cutter will not work.
Nov 03, 2009 | HP DesignJet 500ps InkJet Printer
1. PEN NOT LIFTING. HOW DO I ADJUST PEN LIFT 2.PAPER SKEWS TO LEFT 3. NEED SERVICE MANUAL ON SUMMAGRAPHICS PLOTTER HI7200
Installing Pens
Most types of disposable pens must be activated before using the for the first time. If you are installing a new disposable pen:
  1. Press down on the pen cap to break the internal link seal.
  2. Holding the pen with its tip pointing down, shake the pen to start the ink flow.
  3. Remove the cap and test the pen for ink flow on a scrap of paper or media before installing it in the plotter.
    Some types of pens require adaptor sleeves to fit the pen holders in the pen changer and pen carriage. Insert each pen into its adaptor sleeve, if required, before installing it.
Using the Pen Changer
You may find it easier to temporarily raise the pen changer arm to install pens. Press the widest part of each pen into the jaws of each stall in the pen changer. After installing all the pens that you plan to use, lower the pen changer arm until it latches into place.
Notice that the pen changer stalls are numbered 1 through 8 from right to left (viewed from the front of the plotter).
Note: Make sure that the pen changer arm is in its lowered position and latched into place each time you power on or reset the plotter so that the plotter will correctly change pens.
Operating Without the Pen Changer
For operation without the pen changer, position the pen changer arm in the raised position and install a pen directly into the pen carriage by pressing the widest part of the pen body into the jaws of the pen holder on the pen carriage. You can still produce multi-pen plots, if desired, by enabling the PEN PAUSE parameter--------------Online KeyThe Online key toggles the plotter between on-line and off-line operation. The mode is displayed with each key press.
The plotter is initally in the on-line mode at power-on. In the on-line mode, plotting operations are enabled. When media is loaded in the plotter and the plotter has been selected (see below), an on-line plotter begins executing plotting commands from the input buffer as soon as they are received from the host computer.
In the off-line mode, the plotter can still receive data into its input buffer if it has been selected, but plotting operations do not begin until the plotter is switched on-line. The plotter can be operated manually in the off-line mode using the following control panel keys:
  • Pressing the left or right arrow key moves the pen left or right.
  • Pressing the up or down arrow key moves the media in or out of the plotter.
  • Pressing the PEN SELECT key accesses a menu to select a given pen from the pen changer.
  • Pressing the PEN UP/DN key raises or lowers the pen.
Pressing the Online key during plotting switches the plotter off-line and suspends plotting.
Pressing the Online key again will cause plotting to resume at the point of suspension. ------------------Pen Up/Dn Key
The Pen Up/Dn key raises and lowers the pen when the plotter is off-line. If there is no pen in the carriage, pressing the Pen Up/Dn key causes the plotter to retreive the currently selected pen from the pen changer (if the pen changer is installed and is in the lowered position).
Note: After approximately two seconds of no pen movement, the plotter will automatically raise a lowered pen to prevent ink from bleeding on the media, until the pen is moved again. If the pen is not moved for the period set for the AUTO-CAPPING parameter , the plotter will return the pen to its pen changer stall. To restore the currently selected pen to its previous position on the media, press the Pen Up/Dn key or an arrow key. Pen Select Key
When the plotter is off-line, pressing the Pen Select key allows you to select a pen from the pen changer. After pressingPen Select, press the <-- --> keys until the desired pen number is displayed on the lower line of the LCD, then press the Enter key. The plotter will retreive the selected pen from the pen changer.
The Pen Select key is also used in the Configuration Menu,
Oct 16, 2009 | Computers & Internet
Both green and orange lights blinking. Printer
Try deleting all ready to print documents, restarting the printer and then re-booting the computer. Somebody in there is confused.
If that doesn't work, check your documentation on how to print a test page, if it will print then the problem is which the application otherwise re-install the printer.
Oct 09, 2009 | Castelle LANpress Jr. MP (66298601-040)...
Castelle LANpress Jr. MP (66298601-040) Print Server Logo
141 people viewed this question
Top Castelle Computers & Internet Experts
Ekse
Alun Cox
Are you a Castelle Computer and Internet Expert? Answer questions, earn points and help others
