Brooks s4368 smoke detector
Change backup battery
4 Suggested Answers
SOURCE: smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Posted on Jul 17, 2008
  • 5 Answers
SOURCE: How to change the battery in my SCO5RVA smoke and
Not obvious, and th emanual is not too precise about this as you probably know.
What I did on mine: take it off its bracket, flip it over bottoms up. You will see a part of the "rim" curving slightly out, that's the battery cover lid.
It is a very tight fit; to make things relatively easy, rotate the unit with the bottom still facing up until the curved part is on the right of the unit. Make sure there is no (red, if I remember correctly) peg locking the compartment closed, then insert your right thumb in there, and pull out. The battery compartment will eventually slide out part of the way. Remove the battery by pushing them out from below the battery compartment; they are on two separate blades that can be used to push them out.
Shoudl do the trické
Posted on Aug 07, 2010
joeguest2
  • 2080 Answers
SOURCE: smoke detectors keep saying low
Occasionally these units can malfunction due to a buildup of dust inside which can interfere with the smoke sensor. Try opening the cover to the smoke alarm and vacuuming out the dust, or better yet, get yourself one of those cans of compressed air that are used for cleaning computer keyboards and thoroughly blow out all the dust.
Just to be certain, you can always test the new battery with a voltmeter to ensure it is in good condition before you put it in the detector. If you buy the really cheap brands of batteries, you will sometimes get one that is dead right out of the package.
Once you have inserted a good battery, try activating the smoke alarm using the TEST button.
If the smoke alarm continues to beep unnecessarily, then it is likely an internal fault and it's simply time to replace the unit with a brand new one.
Please comment back here to this page if you have any details to add, have any questions, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe
Posted on Aug 04, 2011
Open brooks smoke alarm to change battery
Hi Robin
Usually push in (up) & turn
Feel it as you turn
.....then remove from other half.
Have 9v battery handy for replacement.
Mar 05, 2015 | Brooks Kidde 120 VAC Photoelectric Smoke...
Nortron smoke detector
It may be urging you to change the battery...
May 09, 2014 | Home
No, I didn't find what I was looking for, an answer to the following question. The Kidde Ionization Smoke Detector 1275 is electric only as it has no battery backup and it continues to chirp after the...
The 1275 does have a battery backup according to the manual on the Kidde website. Try this URL to get a copy of the guide:
https://portalgb.knowledgebase.net/al/15121/16372/article.aspx?aid=295779&tab=browse&bt=4&r=0.1818646
Aug 04, 2011 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
This is one of 6 in our house. It is emitting light chirps every 30 seconds or so, I thought maybe this meant low battery, so put in a new one. no change. I can't take it down or apart, and want it...
Check ur main a/c source of power yet?This kind of smoke detector draw alot of power.Battery replacement should used the best kind of batteries out there like Duaracell,Energizer or litium rechargable batteries.After the replacement of the battery,should press the reset button like for at leat minute for the smoke detector to go off for about 30 sec. for it to dectect the new back up battery power source.Should solved this lower power detection problems.
Jul 04, 2011 | Kidde 4618 Firex Hardwire Ionization Smoke...
One beep constantly on smoke and CO unit. says battery low but the system is wired into house panel. Help!
Most new smoke detectors work off of two power sources, electric and battery backup. The battery is used to power the detector if primary electrical AC power is lost. It would be a good idea to replace all detector batteries every two years or so. You'll access the battery by opening the unit, find out the type used and then purchase a replacement at your local store. Hope this helps.
Apr 15, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Kidde smoke alarm won't stop chirping . I have replaced the batteries and nothing seems to fix the problem
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
Mar 21, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Kiddie fire alarm model I12060, beeps once every
This happened to me, my smoke detector started chipping so I changed the batteries. A few seconds later it started chirping again. The answer is in the way you put the batteries in. The smoke detector allows you to put the batteries in wrong and makes a slight connector. This slight connector tricks the detector into thinking the batteries are weak. Simply turn the batteries around so the fat connector of the battery touches the skinny connector of the device. Mine was, fat side on the right.
Jan 28, 2010 | Kidde i12040 Hardwire Smoke Alarm with...
Computers & Internet Logo
David Payne
David Payne
