Washing machine water fill up tub and run's over on any level and will not stop. will not wash. it will only fill the tank and spin.
  • 4 more comments
  • Anonymous Oct 27, 2008
    it only fills with water and spins help
  • luisborjas Nov 29, 2008
    I have a leak of water on my GE WSM2702DWV1 spacemaker laundry. How can I uncover it to correct the problem? I leave in Venezuela and I would like to obtain the repair manual or your help comments. Thank you, Luis
  • Anonymous Dec 02, 2008
    My washing machine overflows. when i put it on spin it drains with no problems.
  • ofalia33 Dec 08, 2008
    My washer fills up to the max then drains and slowly spins for a few seconds and shuts off with an "oL" fault. Paid $70 for a Sears Tech to come out and tell the cntrl-elec board is the problem. Declined the quote of $568.25, and ordered the part myself. Changed it out and it still did the same thing. Performed diagnostics, step C1 failed. It filled up all the way then kicked out the "oL" fault. Turned it off then the "F1" error popped up. Reinstalled original board and will try to return the one I ordered. Followed the troubleshooting guide for the "over fill" problem still got the same problem. Pressure hose seems to be in good shape. Any other ideas???
  • Anonymous Feb 17, 2009
    washer will not agitate
  • Anonymous Mar 23, 2014
    When the tub in my washing machine is filling the water keeps running and runs over in the floor.
  • 291 Answers
What kind of washer and model # ? Sounds like.. You have a bad pressure switch or the small hose connecting to the pressure switch may be bad or the connection on the switch or tub is linking air pressure I seen where mice had chewed holes in them
Posted on Aug 29, 2007
    Genius:
  • 1,122 Answers
Check the presure dome hose at the presure switch and at the dome if all looks fine an you have a bad fill valve,let the washer fill start filling leave it on,now unplug the washer if the water keeps coming in then the valve is bad-mike
Posted on Jun 30, 2009
4 Suggested Answers
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
defadad
  • 351 Answers
SOURCE: washing machine overflowing
the valve on your inlet pipe may be faulty, have the valve checked or buy a new valve, not very dear, around $30 australian
Posted on May 30, 2009
Maytag317
  • 1136 Answers
SOURCE: washing machine will not spin
Hi, If this model has a belt, you might need to replace it. Once the belt gets wet, they are ruined. If the motor runs during the spin cycle and the tub does not turn, it is most likely the belt. If the motor is not running in the spin cycle, we need to look at other causes. If I can assist you further, please get me a model # so I can see exactly what washer you have.
Thanks
Vic
Posted on Jul 17, 2009
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Tip
The washing machine is under filling water?
This problem is due to fault in the Water-level switch in washing machine.
The Water-level switch is the part in the washing machine that senses the filling water in the tub. When the water reaches to its required quantity the Water-level switch sends the command to stop the water supply. But if the Water-level switch is faulty. It will sense the wrong quantity of water in the machine. And makes the water supply stop bit early then required. So washer does not fills with required water .The Water-level switch is located at the bottom of the outer tub in the washing machine. Many a times removing and reconnecting the switch makes it proper. in other cases it needs to be replaced.
These will help. Thanks
on Mar 18, 2010 | Washing Machines
The water level selector of my whirlpool white magic-splash washing machine is causing problem..it does not stop the water at the desired level..the water keeps on flowing into the tub and then overflows...
PRESSURE SWITCH
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Mar 09, 2011 | Whirlpool Washing Machines
Admiral washing machine keeps filling up and will not stop till I turned my water valves off, and then it will not wash the clothes but will spin them .
The water level sensor is faulty. After the inlet valve is opened the program controller needs the signal fromt he water level sensor. Thi is normally a pressure switch and as the water builds up the tub through a small opening the water flows through a tube to trigger the switch. So find out the pressure switch and replace. Only once the sensor clicks will the program proceed to wash . Otherwise you can spin becasue the water level sensor need not work for spinning as the level is down.
Sep 17, 2010 | Admiral Washing Machines
Washing machine overflowing
May 30, 2009 | Whirlpool AWZ412 Front Load Washer
Maytag MAV5000 washer, water filling does not stop, small tube in back is hooked up.
Remove the small tube from the water level switch and blow through it to clear any clog in the air dome on the side of the tub.
Remove the small tube from the air dome and blow through it into the water level switch to reset it.
Then set the machine for spin and run spin cycle for 1 minute. Then try your fill again. If it does not work this time, replace the water level switch.
May 21, 2009 | Maytag Washing Machines
The washer filled up with water and just started to tick, didn't spin, didn't wash. What should I do.
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
click the link
http://www.applianceaid.com/maytagwash.html
Nov 29, 2008 | Maytag PAV2300 Top Load Washer
When washer is in super wash cycle water will not stop causingthe tub to over fill running onto the floor.
It sounds like you are trying to use the largest water level setting. If this is correct you may have a pressure switch problem.
First turn the timer to spin and get all of the water out, that start a washer cycle with the water level set to the small or low setting and see if the washer fills to this level. if it stops at the low level great Now if it continues to fill and does stop you may need a pressure switch or the hose needs to be replaced that runs from the tub to the pressure switch.
Now set at the medium level and try again. does it stop or over fill?
If it over fills you probably need a pressure switch however before you purchase this, make sure the hose is in good condition one pin hole will cause your overfill condition.
Jul 09, 2008 | Washing Machines
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
1,335 people viewed this question
Top Washing Machines Experts
