Question about Samsung PN51E450A1FXZA 51-INCH 720P SLIM PLASMA HDTV
Samsung pn51e450a1fxza LED BLINK
MY TV DON'T START WITH THE POWER LED BLINKING
3 Suggested Answers
vittala
  • 318 Answers
SOURCE: how I'm Connect the bottom
what is the model, i l get you the manual
Posted on Jun 16, 2011
ekcnoel
  • 998 Answers
SOURCE: Bought this TV used and was told it needed a
Sir when replacing the bulb you should reset the lamp hour meter. 1. while on the standby mode press "mute" then the numbers 1,8 and 2 in succession, and press the power button.
2. wait until "loading factory" appears on your screen and the service menu is displayed with the lamp life hours. You will see a list of service options.
3. Scroll down to "option" and press "enter". next you will see "reset lamp" where you will press again the "enter" button. good day and best regards.
  • 2 Wait until "Loading Factory" appears on your screen and the service menu is displayed with the Lamp Life Hours. You will see a list of service options.
  • 3 Scroll down to "Option" and press "Enter." Next you will see "Reset Lamp" where you will press again with the "Enter" button.
  • Read more: How to Reset the Lamp Hours on the TV ' eHow.com http://www.ehow.com/how_5535314_reset-lamp-hours-tv.html#ixzz1VIGJC5k7
    Posted on Aug 17, 2011
    My sharp the power led blink when u press power
    some TV models will blink the power LED when starting up that is due to the firmware booting in the TV say like Samsung TVs they will blink the power LED when their starting up before it makes the samsung startup sound but if the tv isnt showing anything or making any sound it may need to be checked
    Mar 14, 2017 | Sharp Televison & Video
    Tip
    Laptop LED Blink on Startup There are many reasons that a computer does not...
    There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
    Startup Symptom: LEDs blink but does not start
    The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
    DO THESE FIRST - Perform a hard reset.
    If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
    1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
    2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
    3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
    Identify the number of blinks or beeps
    When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
    Table of Sample Blink Codes
    The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
    Meaning of Sample Blink Codes for some EFI Notebooks:
    1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
    Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
    2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
    Error Condition: CPU not functional
    3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
    Error Condition: BIOS corruption failure
    4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
    Error Condition: Module error not functional
    5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
    Error Condition: Graphics controller not functional.
    6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
    Error Condition: General system board failure.
    7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
    Error Condition: BIOS authentication failure.
    8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
    Error Condition: Insufficient power
    Common solutions for issues that cause blinking LEDs or beep tones
    When the computer can boot into the BIOS, run the memory test to identify other issues.
    Check for loose connections and test the memory
    Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
    Check for loose memory modules
    If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
    on Mar 21, 2011 | Computers & Internet
    My Samsung un50es6150fxza LED TV won't power on. The red status led on the front blinks a pattern of 10 flashes in series of 2 (blink,blink, pause, blink,blink, pause..) Is this flash pattern a code?
    Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
    http://electro-medical.blogspot.com/
    Jan 22, 2017 | Samsung Televison & Video
    My 55" plasma Samsung tv model number PN51E450A1FXZA. The red power standby light is lite but when you hit the power button it blinks and returns to a solid red with no picture or sound
    These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
    Nov 06, 2015 | Samsung Electronics Samsung 51" E450...
    Is PN51E450A1FXZA a smart tv?
    Click on the link below, and search that PAGE for the word "smart" ... but without any quote marks!
    https://www.google.com/?gws_rd=ssl#q=Is+a+PN51E450A1FXZA+a+smart+TV?
    Feb 27, 2014 | Samsung PN51E450A1FXZA 51-INCH 720P SLIM...
    Power led and lamp led blink simultaneously on my jvc hd65s998 rear projection tv
    You might need to replace your lamp driver, or ballast as some call it. This is what strikes the lamp to make it light.
    Mar 20, 2013 | JVC Televison & Video
    LG 26LX1D. Has worked for 2 years. Recently moved but the day I left I was still watching the TV and then wrapped it in a thinks blanket for protection and placed it ontop of several winter coats for more...
    It's possiable the powerboard is just not filling those cap's to capacity, this would explain why the green light does not come on, also what can be possiable is a relay in the power board that is not passing the 110v. I am uncertain of cause.. However 5days would drain the capictors to a point where the refilling process failed. I am just wondering if it got could in the structure? IF so how cold. Eletronics only can handle a certain temp.
    I would say power board.
    Feb 11, 2012 | Televison & Video
    Samsung PN51E450A1FXZA 51-INCH 720P SLIM PLASMA HDTV Logo
    Henry  Thomas
    Henry Thomas
