Question about Garden
Craftsman lawn tractor model 917 272352
Which way are the mower blades suppose to go clockwise or countercclockwise
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
  • 4 Answers
SOURCE: What year model is lawn tractor (mower), advice or solution
Hi there Avu
It's quite east to see when was your tractor was made, follow these simple steps and you'll know how to see what model it is
  1. Lift the tractor / mower seat (pull it up)
  2. You will see there's a small metal label with the serial and model number of the tractor / mower
  3. Check the serial number of the tractor / mower
  4. the first six digits of the number are you the model month day and year (i.e 090999XXXXXXX this tractor was made in September nine in 1999
Hope this helps
Attached is an image of the tractor seat and the metal plate
Posted on Sep 21, 2009
Testimonial: "I did it and there it was, Thanks a lot for the help with the solution for this lawn trctor problem"
mowerman1857
  • 389 Answers
SOURCE: Craftsman lawn tractor, model 917.270711, smoking and stalling
That is a Briggs & Stratton engine and given its age, I would say it is time to overhaul or replace the carburetor. Over time the float needle and seat become worn and inoperable which is why you are getting fuel in your crankcase. If you are not familiar or comfortable with working on these things, this is a job better left to a professional. There are too many things that can (AND WILL) go wrong in trying to do it yourself. Just scan through some of the questions on here and see how many others have taken theirs apart and can't remember how to put it back correctly!
Posted on Oct 11, 2009
My craftsman riding mower vibrates so bad when I engage the mower. How do I stop vibration?
Things you need to check, loose blades, blades out off balance, bad belt or loose belt, bearings in the blade mandrels worn.
Jun 29, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades turn when not ingaged to turn
This will be due to belt drag. There is a blade brake fitted that is supposed to push brake pads onto the pulleys when the blade clutch is 'out'. If either the pads are worn, or the spring is missing/broken/dosconnected, that will be the problem.
May 12, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn mower blades won't enage
Go to Sears web site put in your model number and you will find all your info there. http://www.searspartsdirect.com/partsdirect/index.action
Mar 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Changing out the blades...are the attachment bolts reverse thread or normal, i.e. clockwise to tighten?
Should be clockwise to tighten, use some "PB blaster or Deep Creep" penetrating oil on the bolts before trying to take them off. It will help.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mounting snow blade to lawn tractor
Sep 29, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
