Sound keeps dropping out
Has just started doing this will be watching tv and sound drops out with a clicking noise for a couple seconds then back on
    Genius:
  • Audio Player... Master
  • 1,054 Answers
What brand/model?
Posted on Jul 19, 2013
Testimonial: "Onkyo model tx 705"
SOURCE: Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Posted on Jan 28, 2008
dunnbiker
  • 8546 Answers
SOURCE: Sony STR-DE475 - Sound levels dropping
When did this start? Did it ever work right?
How's the sound from your TV speakers by itself and from DVD? The same? Problem's in the TV.
If it's just the receiver doing it from both sources that's where we start.
Check the settings for dynamic range (ratio of loud sounds to soft sounds) in both your receiver and your cable TV tuner. Many devices have a setting sometimes called "MidNight Mode" to be used in the event you're listening while someone else might be sleeping or otherwise would be disturbed by the TV volume.
The assumption is that you will turn the TV down but that normally means you would lose the quiet programming in the background nosie of your home. Through the magic of dynamic compression the quiter sounds are raised to audibility while loud things like explosions and fanfares will be limited in volume. Depending on the design and whatever the broadcaster is doing to the sound themselves this could be anywhere from pleasingly effective to aggravatingly inconsistent with odd variations in the levels.
Hope this helps.
Posted on Apr 03, 2009
  • 227 Answers
SOURCE: humming sound when watching tv,but not when watching dvd's
It wounds like you are getting interference from you tv to the receiver. You can try a few different things here.
1. Connect the tv output into another input on you receiver to see if it isnt the channel on the receiver.
2. Try a different set of cables between the tv and receiver. Faulty cables can give you problems.
3. Connect the cable from you tv to a different device. (another dvd vcr blue ray etc.) This will tell you if its the receivers or the tv.
Posted on Sep 13, 2009
smarthome2
  • 1114 Answers
SOURCE: when watching HD channels the sound drops out for
If it's thru Cable TV, your feed may need an amp. If your on FIOS or DSS, I'm stumped. How many boxes are in your house and how many locations are set up for TV and have no TV hooked up? If any, you need to try "F" caps at the empty locations, it causes signal loss. If all locations are terminated, the Cable company needs to ramp up the feed. They can do this via phone if you have Comcast or Bright House, otherwise, just call and ask. Hope this helps
Posted on Dec 26, 2009
Testimonial: "Thank you... I suspected that the cable box may be the culprit. I will contact Grande cable this week. I appreciate your help, thank you again."
dunnbiker
  • 8546 Answers
SOURCE: I have a SAmsung HTZ310R home cimema system and
Sounds like a couple of coincidental but unrelated symptoms.
Optical cables need precise seating and no tight bends.
Muffled, channel-specific sound is usually on the analog end. Speaker connections maybe.
Posted on Mar 17, 2010
Every few minutes the sound drops out for a couple of seconds. Tv is a Sony and I am watching via sky
Does the TV do this no matter the video source, for instance does it do it when you watch a DVD? If the sound is steady on other video inputs then the TV is not the problem.
Jun 28, 2017 | Sony Televison & Video
Was watching a movie when T.V. shut off and won't come back on. Keeps making a clicking sound when I try to turn it on.
Sounds like a main board fault. Contact any service technician. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 02, 2013 | Televison & Video
I have a new Sanyo TV with a build in DVD player. I have started having audio issues. I have not had the TV for a year yet and the audio has started spiking loudly out of now where for a couple of seconds...
Pl. check the variation of volume while you listen the sound,if no change than the problem is with the circuit,contact company service center.Also check by tapping on the speaker grill with your hand if the speakers are jammed than the sound will come intermittent,replace speakers.
Jan 15, 2011 | Sanyo Televison & Video
I was watching tv and out of nowhere the tv turned off and now will not turn back on for more than a couple seconds. When it does turn on it makes a click noise then turns off, with no sound or picture.
Dec 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Sony 52" Bravia LCD will drop picture and sound for 1-2 seconds
the only thing that i can think of is that the cables and connections are bad but if that is not the case it may be the internal components of the tv. my guess is that the tv was dropped or jumbled around while transported and what happened was internal components were broken or just mixed up so go to the retailer and get a refund or a new tv. hope this helps
May 22, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Dropped external hd not being recognized
replace the hard drive, as dropping it has rendered it totally useless.  be more careful in the future.
Nov 13, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
WILL NOT POWER ON
isolate power from hor.output section. if voltage becomes normal 130v &it does not drop then power supply is ok. now check hor output for leaky compnents near eht specially capacitor & diode. check hor output tr. at last eht. you can clean print near eht.
Sep 10, 2007 | Sanyo DS24424 24" TV
 Grubhead
Grubhead
