What does NG mean on the scanner log please? - Office Equipment & Supplies
Displaying....DSP NG can some one please help? some kind of error.
In my experience, NG on a system made in Japan means "No Good" (error). NG might stand for something else, but regardless, it sounds like an internal issue with the amp.
Sep 24, 2015 | Pioneer VSX-D510 Receiver
How to fix NG in the log list of canon ir3225 that prevent it from printing document from pc
there was no code after NG.The print command is working from the pc but the canon machine ir3225 on the log list it shows the job no and all but in the result section it shows NG without any code.This Makes me headache ,please can any one solve this
May 23, 2014 | Canon imageRUNNER 3225 Black and White...
Cannot log onto facebook for free
There is no fee to log onto Facebook ... what do you mean? Please tell me more about what you want to do.
Thank you for visiting FixYa.com
Aug 22, 2011 | Computers & Internet
Ang problema ng cpu ko ay may power cya tumatakbo din ang processor.ngunit walang lumalabas sa monitor.
check lahat ng cable lalo na ung papunta sa monitor,tapos try mu rin sa ibang computer ung monitor mu, kung ok naman, open mu ang cover ng CPU dahandahan mung tanggalin ang memory,linisin mu ng eraser ng maingat ung kulay gold side ng memory.. then try, pag wala parin, try mung lagyan ng ibang ayos na memory, kung may tunog naman, 1 Long 2 ShortVideo Card Error - Either re-seat or replace video card,Repeating beepsMemory Error - Memory is either damaged or badly seated.
Aug 12, 2011 | Computers & Internet
Bakit kailangan ng batas
  • Ang batas militar ay mahalaga sa bansa sapagkat dahil dito ang pamahalaang militar ay napanatili ang kaayusan ng bansa, nakapagtatag ng hukumang sibil at nakapagtatag rin ng pamahalaang lokal at,kailangang magpatupad ng batas para sa kalikasan upang hindi tuluyang masira ito. Umaabuso na kasi ang mga tao sa kalikasan. At ang mga batas na ito ay para sa ating kapakanan. Kung hindi natin pipigilan ang illegal logging, makakalbo ang mga kabundukan at magdudulot ng landslides. Ang mga basura naman na itinapon sa mga ilog, kanal, at estero ay magdudulot ng baha. Kung wala ang mga batas, magpapatuloy ang mga tao sa pag-abuso at siya ring papatay sa atin.
Jan 25, 2011 | Briggs Garden
IR3025 can not print, Status NG
Try to enter service mode: * 2 8 *
COPIER
FUNCTION
CLEAR
ALL
OK
TURN OFF AND ON
NOTICE: WHEN YOU CLEAR ALL THAT MEANS THAT YOU WILL HAVE TO INSERT ALL SETTINGS THAT YOU MADE, LIKE IP, GATEWAY, EMAIL FOR SCANN...
May 06, 2010 | Canon ImageRunner 3025 Black and White...
Ang problem q eh!gzto qng mlamn qng mron bng mga code sa add comment ng friendster,.?
This is the instruction on how to place the code above into your frienster.
1. Log into friendster
2. Click on profile
3. Click on edit profile
4. Click on customize
5. Then go scroll down he page to Advanced Customization(customize css)
6. In the box below the Advanced Customization(customize css)
7. Paste the copied code for your background into the box.
8. Then save
9. Then click on (view your profile now) to see your new background.
You can find background codes at http://www.informationzoo.com/Friendster.html
Mar 17, 2010 | Zebra MS9540 Voyager Hand Held Scanner -...
What does NG mean in the TX/RX log?
NG just means the fax was unsuccessful or No Good. After the NG should be another number code that tells what type of error it was. Could be busy on the other end, poor line quality, or any number of things.
Jan 12, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon ImageRunner 2016 - scanner Not working properly
Ir 2016, can be onlly pull scanner, so that means that you must have installed scan gear, selected in scan gear, and over microsoft word or similar insert scan ( INSERT PICTURE FROM SCANNER OR CAMERA ), but the machine must be in scan mode, put original on platen or dadf, and then "pull it"from PC.
Hope that helped
pls.rate
Sep 30, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
I have a Canon ir 3045 copier, when I try to send the scanned copy directly to a file, the file doesnot save to the destination network folder. When I looked at the scanner send logs i saw status as NG...
I have a Canon ir 3045 copier. I had sucessfully scanned two documents but the third scanned document (107 pages) was not emailed to me. When I click on press details, the job type reads #801. how do i retrieve the document?
Apr 24, 2009 | Office Equipment & Supplies
20 people viewed this question
jasbo
jasbo
