Question about RCA DRC620N Portable DVD Player
Adapter plug size
I need a 12volt/1.5A, center pin positive, charger. The problem is on the DRC620N the center pin is much smaller than one would expect a 2.1 mm inside and 5.5 mm outside. I am pretty sure the outside is 5.5, but the inside pin is a good bit smaller than 2.1. How do I find out what plug size is correct?
  • JennySue12 Jun 18, 2008
    I have the same problem and I bought the device from Walmart. It does not work, none of the adapters work on that device.
    I have been working with RCA or some company associated with them since January of 2008, its now June and no resolution. I will never buy an RCA device again. I have a perfectly good, almost new DVD player that I cannot use because I cannot charge the battery!
    Champion:
  • 303 Answers
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger cord RCA DRC620N
Posted on Mar 29, 2009
Wal-Mart ectronics dept. has an "Universal DC Adapter Kit" it will have various size adapter plugs and a variable setting to adjust DC Voltage. It also should have a switch to set the polarity. I used mine to power several different devices. It was well worth the money I spent as opposed to buying a actual DC Adapter. Subsequently, the kit from Wal-Mart was far cheaper than the real deal.
-marshall.
Albuquerque, NM
Posted on Jan 20, 2008
SOURCE:
I need to know the POLARITY of the AC adaptor to provide the correct setting using a universal adapter.
there is no polarity in ac current as ac means alternating current and that means alternating between positive to negative back to positive back to negative and so on
only dc ( direct current ) and the center pin of the plug is designated as the positive pole has polarity, the outer case being the negative
OR Are you asking the voltage of the ac adapter and the voltage of the dc output side of the adapter
Nov 26, 2015 | Office Equipment & Supplies
Why would a year and a half old dell laptop stop charging and give the message "use a 65a Adapter" which is what the laptop came with and I'm using.
Dell uses a 3 pin charger.. inner ring, outer ring, and center pin. The center pin tells the laptop what the rating of the charger is. Is the pin broken? or bent.. or perhaps the charger is bad
Aug 17, 2015 | Dell Inspiron Computers & Internet
Why doesn't my HP, Toshiba, Dell, Compaq or Lenovo A/C adapter charge my Acer 5560-7414?
hi there is one for sale on E/BAY US $11.98 PLUS DELIVERY ...cheers
Apr 23, 2017 | Computers & Internet
Can i use any charger on s505
The Toshiba Satellite 5205 series of Notebook PC, and the S505 series model; uses an AC adapter (Charger) that produces 15 Volts DC.
http://www.sparepartswarehouse.com/Toshiba,Satellite,5205,PS520U-31P1RV,Laptop,AC-Adapters.aspx
You will see AC adapters sold that show 15 to 24 Volts. (DC)
http://www.duracelldirect.com/toshiba_satellite-5205-s505_ac-adapters_laptop_ac-b20h.aspx
This is because the AC adapter (Charger) has PFC.
Power Factor Correction,
http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-Power-Supplies/181/2
Also I see it is just a two pin AC adapter plug, to laptop.
Center hole is Positive, outer metal cylindrical metal shell is Negative.
Go for 75 Watts or higher though, and not a 65 Watt model.
[ On the case of the AC adapter;
Input: 100 ~ 240 VAC 50-60Hz
Means it can use from 100 to 240 Volts AC, and either 50 or 60 Hertz.
Output: 15VDC 6A
Means 15 Volts DC at 6 Amp's. (Amperes)
Watch the outside dimension of the cylindrical part, and the center hole dimension. Outside cylinder may be correct, but center hole may be too small. Or vice-versa.
Regards,
joecoolvette
Dec 17, 2012 | Toshiba Satelite 5205-S505 Notebook
How I can convert 110volts to 220 voltage in Craftsman charger 145301 because in the Peru country we use 220 v. thanks.
_Some_ chargers will allow a range of input voltages. This will probably be "Input: 100-240V" or something like that written on the charger. __You need to be sure__. Others may have a switch from one voltage to the other. The trick here is to make sure the switch is in the right position. In both cases you may also need a plug pin adapter. If the charger you have has neither of those abilities then you either need to get a different charger from Craftsman, or get a voltage converter, which will give both the right plug for your wall sockets and convert from 220V (from your wall) to 110V (to the charger). Unless the charger has voltage range or a switch, you can't just use a simple plug pin adapter.
Feb 20, 2011 | Craftsman Drills
I have vectorlite 1.5 Million Candlepower light I want to know the ac charging adapter specification. We kind of lost track of particular adapter in recent moving :(. we appreciate your help....
Most of the Vector spotlights use a class 2 charger with an output of 12VDC 400ma with a positive (+) center connector, which are very common. I have several of these chargers from different manufacturers, and I use them interchangably on whichever spotlight I happen to plug them into.
One complication with my Vectors is they use a coaxial connector plug on the spotlight end that is a size N, which is being phased out and Radio Shack doesn'd even carry any more. If you hae a box of misc chargers, find a 12VDC one with a connector that fits your 1.5MCP light, and that is probably the one that came with your light.
Note that you can also charge your light with the cigarette lighter adapter cord that came with it. So if you can't find an AC transformer that fits but you have your cigarette lighter adapter cord, you can buy one of those cigarette lighter size gadgets that plugs into an AC outlet, and then plug your cigarette lighter cord into that.
Jun 28, 2010 | Vector 1 Million Rechargeable Spotlight
Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
Feb 20, 2010 | JUMP START SYSTEM
Hey i had my dell inspiron 1525 for quite a while and now the charger stopped working for some reason. i need help
The charging circuit requires an ac adapter with an intact sensing pin in the center of the Adapter barrel plug that connects to the computer. If the pin is bent or broken, the charger is disabled.
If possible, try a known good adapter from another D or E Series Dell Portable. If a KG adapter charges the battery, replace the adapter. If it makes no difference, then replace the motherboard
Jan 22, 2010 | Dell Inspiron 1525 Notebook
GP4101 Powere Supplay
The Ultra AC Adapter has the following output specification.
Rated Output Voltage - 9 Volts DC at 200 Milliamps to 1.3 Amp Max
Center of pin Positive
Pin Size
Length - 9.5 mm
Width - 5.5 mm
Center Hole - 2.1 mm
Sep 03, 2008 | Gyration Ultra Cordless Optical Mouse
RCA DRC620N Portable DVD Player Logo
156 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
