Question about Garden
What is the spark plug gap setting for Stihl MS 210 C chainsaw
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
  • 82 Answers
SOURCE: where is the spark plug located in a stihl 026
It is in the circled location on the image below
This came from the manual located at http://www.stihlusa.com/stihl_ownersmanuals/026_Manual.pdf
If this helps please leave feedback
Posted on Feb 04, 2010
  • 3 Answers
SOURCE: where can i find a
e-mail me at herman_g69@yahoo.com and i will send you a pdf for the parts manual
Posted on Oct 13, 2010
yosemyt
  • 322 Answers
SOURCE: air gap and spark plug gap 025stihl chain saw
the air gap is about a business card thick and the plug gap is .020. Stihl has a special tool to measure exact air gaps so the business card is close
Posted on Mar 20, 2013
lpfaff1
  • 11573 Answers
SOURCE: need part # for spark plug wire on Stihl chainsaw model ms 180 c
Robert, NGK BPMR 7A or BOSH WSR 6F , (gaped at .020"/ .5 mm) are what is recommended in your manual pg. 52., Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.stihlusa.com/WebContent/CMSFileLibrary/InstructionManuals/STIHL-MS-170-180-Owners-Instruction-Manual.pdf
Spark plug cross reference
NGK 4626 BPMR7A Standard Spark Plug Pack of 1
NGK BPMR7A Yard Garden Outdoor Living eBay
Posted on Jul 30, 2016
Part # for spark plug wire on stihl saw model ms 180 c
spark plug wires on small engines are normally part of the coil so you may have to get a new coil pack
talk with stihl service parts or service shop
Jul 30, 2016 | Stihl Garden
How do I change a chain on a Stihl ms 210?
Take off the side cover at the base and loosen the tension screw. Blade should slip off. Make sure when you replace it, you do not tighten it too far.
Sep 20, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
What is the spark plug gap on a MS210?
According to page 62 in the Stihl user manual:
Spark plug (resistor type): Bosch WSR 6 F
Electrode gap: 0.02 in. (0.5 mm)
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/STIHL-MS-210-230-250-Instruction-Manual.pdf
Apr 28, 2014 | Standard Oregon Chainsaw Chain For Stihl...
Spark plug gap for a stihl 018c
it should be 0.5mm/0.02" (A)
Feb 17, 2014 | Stihl Garden
Air gap and spark plug gap 025stihl chain saw
Mar 20, 2013 | Stihl Garden
Have stihl ms 210 chainsaw cranks will idle boggs out when you give it gas adjust highspeed then want idle been threw carb twice its clean [ help]
if it is ideling ok I would check the air filter first , try running it without filter in clean air enviroment, Then check the spark plug, clean or replace if necessary, then attempt adjusting carb...
Dec 11, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
