Question about Linear Corporation Linear AK-11 Keypad Access Device - AK-11
Ak11 loses codes
Linear AK11 keypad access. It is less than 2 years old. It has been losing codes for the past several days. The manager code didn't work yesterday, but works this morning. Now it won't work again. What could be the problem?
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
My Panasonic Linear ES8003 is losing its charge within 24 hours of being off base. It's over 6 years old. New battery? Can you send me one?
Here on this web site we are not allowed to send people parts for there products.Help solve problems and tell people where to go for parts yes.
Aug 31, 2010 | Panasonic Linear ES 8003 W Electric Shaver
Have you heard of a bosch TYPPDR211.MATRIX AK11/M01 PRINTER
is it dot matrix type, they are old if is and there are no info on them any more, would be in a museum if any left. or if it was none listed i.e a tester and not manufactured there would be no listing for it aswell, i have had a few things that never past the testing phase.
Jan 20, 2010 | Bosch ENVE2460CT Printer
Teach me how to unlock the samsung gts5230 if i forgot the phone lock code
key in *2767*3855# the phone should restart and return all codes to factory Default, this is a hard reset so you will lose all data on the fone (back to as new) so back it up first!!!!
Nov 13, 2009 | Samsung Cell Phones
Sony KDF E42A10 picture loses quality.
It sounds Lamp is weak and causing darker picture.
How old is this TV and did you replaced Lamp recently?
If lamp has not been replaced in past 2-3 years then its time for new lamp, XL-2400 available in Sony Accessories Store and lamp replacement procedure is written in user manual.
Thanks.
Nov 05, 2009 | Sony KDF-E42A10 42 in. LCD Television
Logitech Ex110 keeps losing connection
Ok wht you need is batteries (preferably rechargable save the earth etc) There is a slot on the back of the keyboard where i think 2 or 3 batteries can be placed in the keyboard take a gander and tell me what ya got.
Oct 18, 2009 | Logitech Wireless Access Duo Optical...
My shaver doesn't stay charged very long
The motor is fine, what happens is that the internal battery loses the ability to fully charge and run the motor for a long period of time. While you "could" change the battery out with a newer one using solder, it's unlikely that it would cost less than buying a newer model at the store or from ebay. The average life of good shavers made a few years ago was about 3-5 years due to the type of batteries in it. I used mine with a charging cord for a while but that became an issue once while traveling. I bought a new one.
Nov 09, 2007 | Panasonic Classic ES 7006 N
Linear Corporation Linear AK-11 Keypad Access Device - AK-11 Logo
50 people viewed this question
Top Linear Corporation Video Cameras Experts
Are you a Linear Corporation Video Camera Expert? Answer questions, earn points and help others
