Question about ASUS VH238H 23" LCD Monitor
Color profile icc icm - ASUS VH238H 23" LCD Monitor
Clp-620 icc profile
Dear
Pl. down load and install the samsung easy color manager and install it. Here you can control the color setting.
Printer Support SAMSUNG India
Thanks.
Feb 12, 2012 | Samsung CLP620ND Colour Laser Duplex...
I changed from windows XP to Windows 7 64 bits. Now the colormanagement doesn't seem to work. I'm printing in Photoshop CS5 and in my printer settings on the tab advanced settings I choose for...
Let Photoshop do the colour management. Switch it of on your printer (only choose the right substrate). If your screen is calibrated, you can use your screen profile in your working space and choose a output profile and rendering intent when you print to a certain CMYK profile.
Jul 07, 2011 | HP Photosmart 8750 InkJet Printer
I`m trying to run adobe photoshop and it says aoc 919profile appears to be defective...plz rerun ur moniter calibration software.....my moniter didn`t come with software
Here's how to fix this:
Go to Control Panel -> Color Management.
In the Devices tab you'll see the Display: ThinkPad Display (resolution) - (graphics card)associated with the TPLCD.icm ICC profile.
This profile is the one conflicting with Adobe Photohop.
What I did was choose another profile that doesn't conflict.
Check the "Use my settings for this device" box, press the "Add..." button, select the other ICC Profile (the one that appears to me is sRGB IEC61966-2.1) and set it as the default profile.
May 10, 2011 | AOC 919Vwa Monitor
Where can I download the ICM or ICC color profile for the Zebra p330i printer?
Colour calibration is always a bit hit and miss with these. You can get big variations between screen RGB and the YMC that is actually printed.
Try zebra.com in the downloads you can find developer manuals that may aid you. Or contact Zebra directly via the site.
Oct 11, 2010 | Zebra P330i Thermal Card Printer
I have a Samsung CLP-315 laser color printer. I'm trying to find out if there's a *.icc or *.icm color profile for it to use with Adobe Photoshop. Couldn't find anything yet via google or others. Would you...
I have just purchased a CLP 325 and have set it up to get excellent colour pictures using Adobe Photoshop and the icc profiles readily available.
Your current working icc profile could be either Adobe RGB (1998), sRGB, Profoto or another. I would suggest that for everyday work use sRGB, if you are a specialist use Adobe RGB (1998).
Firstly make these changes in Photoshop:
Edit / Assign Profile / ColourMatch RGB.
To print:
File / Print / printer profile should be Adobe RGB (1998)
Illustration attached
Aug 24, 2010 | Samsung CLP-315W Laser Color Printer
Could not read the ICC profile. Saving image canceled.
ICC = International Color Consortium.
The ICC's should be installed in the default printer directory.
Also, you may want to check the printer profile. In printer properties under the "color management" tab check to see if automatic or manual is highlighted. If manual is highlighted, be sure the print profile matches that of the paper you are using. You can select any of the included profiles as the default or add your own from a third source. Such third-source profiles are most often specified by your software provider
Mar 24, 2009 | Epson RX595 Photo All-In-One Printer
Epson ICC profiles
Since there has been no interaction for a lot of months, I think we can call this one "Poster Solution"
Sep 01, 2008 | Epson Stylus C86 InkJet Printer
Bizhub C250/252 ICC Color Profile
HI i am fron DPI Grafica SH and have made test of diferents ICC profiles.
I will tell you how is my system to get to correct colors an sharp texts.
First - i print fron Adobe Ilustrator or Adobe PDF Profesional. If you have your file in Corel Draw export it to pdf or Publish a PDF File.
Second - I select s"sRGB IEC6 1966-2.1" this profile prints acurate fonts and colors that match whit de monitor. Is a little bit desaturate if you compare with " COATED Foagra". This one prints blurry fonts and blur edges.
This is the best result that i can get after print tests with all de ICC profiles.
Greetings and i hope that you can solve this problem.
Nolasco.
Oct 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Picture color is off
Google or lookup in windows help for
setting the color profile of my camera
setting the color profile of my screen
setting the color profile of my printer.
color profiles are methods to determine the disparate ways many items use to display color, by setting the correct color profiles in you pc's hardware items you can view images on the camera, screen or in print and have them look the same. it is possible that your display drivers do not have an appropriate profile for the fuji finepix, icc icm profile files are usually available from the makers, but you have to know which one,ma nd how to install it.
Sep 24, 2006 | Fuji FinePix 2650 Digital Camera
What is ICC profile?
ICC profile can be used in any ICC aware application or platform, and describes usable information to convert into a color space which defined by ICC (International Color Consortium). DiMAGE A1 has a function to embed ICC file to the captured image. Please make use of the function "Embedded Adobe RGB" to use correct color information on application software which corresponds to color management system.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
ASUS VH238H 23" LCD Monitor Logo
144 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
