Question about Welding Tools
Welders Manual for a cig autopak 150 - Welding Tools
Can you reverse the polarity on a old cig transmig 195 so you can use gas less wire
Some do work that way . as for your machine we do not know .
Jan 29, 2016 | Welding Tools
I got a 98 ford f-150 need to know witch fuse goes to my cigarette lighter and auxiliary cigarette lighter plug?
Do you have owners manual if so it'll show fuse boxes and fuse numbers to cig and aux power sockets.
Nov 01, 2014 | Ford F-150 Cars & Trucks
I have a cig 220 I pull trigger to feed wire no wire or sounds happen welders fan is running wire isn't jammed and drive motor is working
first of all check the wiring from the machine to the torch then check that the thermal cut out light isn't illuminated, operate all switches and test on all settings, check the relay on the pcb and any contactors in there if all the above fails to find the fault then chances are a part on the pcb have failed
Oct 30, 2013 | Campbell Hausfeld Welding Tools
Lost manual need to get one clarke 150 en
Hi:
Here's the link for ALL clarke models. I think the 150 TE or 151 NE will be the closest ones.
http://www.clarkeservice.co.uk/product_manuals/mig_welders.shtml
If this was useful to you please vote, Thanks.
Good Luck.
Apr 19, 2011 | Welding Tools
89 F 150 MY CIG LIGHTER SHORTED OUT BY A SCREW BURNT WIRE HARNESS
TURN YOUR CAPS LOCK OFF, FOR ONE THING. No, dont light a match and toss in, get a pro to help you. That '89 will be officially antique in 5 years.
Jul 17, 2009 | 1989 Ford F 150
Horn and cig lighter doesn't work
look under dash just under steering column for a panel with fuse box fuse location on it
Dec 26, 2008 | 1988 Ford F 150
I have a ford f 150 2006 and need to replace the fuse for the cig
fuse F41 i central junction box this is the one inside vehicle. it is located in the right side kick panel
Nov 30, 2008 | 2006 Ford F-150
Welding Tools Logo
124 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
