Question about Garden
Adjusting Simplicity 4211 mower deck
With mower deck raised to high setting it is mowing too low
  • 154 Answers
SOURCE: mowing unlevel mower is brand new
check to see if all the mounts are tight.
Posted on Jun 07, 2009
  • 24 Answers
SOURCE: cutting deck of mower not lowering
Did you check the wires goin to the motor under the frame to see if one of them came disconnected? Or...you might need a new switch.
Posted on Aug 22, 2009
  • 168 Answers
SOURCE: how do I adjust the mower lift on my Husqvarna lth
Some units have a dial style adjuster on the lower section of the dash. However, you may have to manually adjust the two rods under the unit that attaches the housing to the mower. Check this out first to see if this helps.
Posted on Aug 23, 2009
mowerman1857
  • 389 Answers
SOURCE: how to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Posted on Oct 11, 2009
SOURCE: Mower deck slows and stops when I turn my Simplicity riding mower to the left,
HI,
The simplicity has a a two point mounting system for the deck. It attaches to the front axle which has two runners that go to the front axle's rear support bracket.
Closely check the runners near where the pins that hold the mower deck. They are known for cracking and breakage. Secondly, closely check the decks metal center support bracket, it bolts to the center of the deck and supports the idler pulleys as well as the deck alignment and mounting. Those, too, are known to crack near the front just behind the front pulley.
Posted on Aug 25, 2012
How can I raise the mower deck on my Troy-Bilt Bronco 13YX78KS011? On the highest setting (5)it mows very short. After mowing only once on setting (3) the pulley has ground a groove on the adjustment
I hope you have a warranty.. I did have a mower that I had to removes some shims from between the engine and the frame to keep the belt from being misaligned. but of course that has nothing to do with the deck height.
Nov 16, 2014 | Garden
How do you level the mowing deck?
There should be an adjustment on both sides of the deck. Move the nut up or down to raise of lower it.
Jul 03, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
Ariens raise deck
the arms to the deck are adjustable or the wheel fittings will be adjustable
indications are that the cutter deck is either down at the front or the back where it should be level
Jan 28, 2018 | Garden
Replaced deck belt and it keeps coming off,whats wrong?
The belt tensioners on top of the deck need adjusted, or you make have to adjust the pulleys to tighten the belt. Sometimes if you have the deck lowered to low to the ground, uneven terain can cause that. If you have everything adjusted correctly, simply raise the deck another notch and mow.
Aug 09, 2010 | Yard Machines 155 Torque Briggs Stratton...
Mowing the lawn high and low
Mowing the lawn low and hi can only mean where are the adjusters or which is best.
The best height for grass is about 2 - inches for my nickle. There is no best - it is to your taste.
As for adjustments on your unit they are done with the handle that sets your deck height.
Let me know if after reading the instructions you still need help.
thanks
Gary @ Fix Ya
Jun 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I adjust the mower lift on my Husqvarna lth 130 lawn tractor? Can't seem to be able to raise deck high enough when mowing
Aug 23, 2009 | Garden
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
