Question about Radio Communications
Desplaines ilpolice scanner frequency - Radio Communications
I would like to know if there is away I can print out the frequencies & channels for Monterey, Calif Thank You
Yes, go for it :>)
  • Monterey County, California (CA) Scanner Frequencies and ... www.radioreference.com > US > California Scanner Frequencies and Radio Frequency Reference for Monterey County, ... Monterey County California . ... Monterey Regional Waste Management District : FM :
  • N6SPD : MONTEREY PENINSULA POLICE FREQUENCIES n6spd.com/freq/mcfreq.htm 155 rows · CHANNEL # FREQUENCY: TONE: SHERIFF: North Dispatch: 1: 159.090: ...
    • AGENCY TYPE CHANNEL # FREQUENCY SHERIFF North Dispatch 1 159.090 CAL FIRE North Dispatch Command 1 152.720
  • Monterey County Scanner Frequencies (CA) - Intercept interceptradio.com/slocal.php?disp=1&country=US&state=CA&county=... 39 rows · Home of the world's largest radio/scanner frequency database ...
    • Freq PL/M City Call 51.76 114.8 Monterey WE6R 51.82 136.5 San Ardo WR6VHF
  • Monterey Park Scanner Frequencies (Los Angeles County CA) www.interceptradio.com/slocal.php?disp=1&country=US&state=CA&county... Scanner Frequencies for Monterey Park Los Angeles county CA US. ... Los Angeles County Scanner Frequencies (CA) ... Channel Notes;
  • View and Compare Your Scanner Options ' Police Scanners www.policescanners.net/scanners-ca-monterey View and Compare Your Scanner ... About Us; View and Compare Your Scanner Options Monterey County, California Fire Police ... Fire and EMS channels in ...
  • California: Monterey - Radio Scanner Frequencies www.scannerfrequencies.com/radio/california/monterey/page/2 Scanner Frequencies ... USA CA Monterey. Articles Contact Submit. Follow @ScannerFreqs. California: Monterey. Frequency: CallSign: DBA/Licensee: City:
  • California Public Safety Frequencies - Bay-Net www.bay-net.org/frequency_calif.html 866.2000 - Channels 20 & 21 - Northern California. ... to air tactical frequencies. In southern California FIRESCOPE area ... California Public Safety Frequency ...
  • Monterey Park, California - Scanner Frequencies - Phone ... www.cityfreq.com/ca/montereypark Scanner frequencies, phone numbers, ... Monterey Park, California Scanner Frequencies. Public Safety. AHMC MONTEREY PARK HOSPITAL (CARMEN ...
  • FCC Licenses and Scanner Frequencies for Monterey County ... www.radioreference.com > US > California > Monterey (County) FCC Licenses and Scanner Frequency Listing for Monterey County, California ... US > California > Monterey (County) County Home;
  • Monterey County Frequencies - Scanning California www.scancal.org/old/monterey/county.html Monterey County Napa County ... Scanning Central & Northern California Frequencies Monterey County Last Updated: ... Channel 2 - Secondary
  • Feb 04, 2016 | Radio Communications
    Can you listen to a police frequency if it's trunked with this scanner? Uniden BC72xlt
    You can listen to trunked police bands UNLESS: 1 they went Digital and your scanner is Analog. 2. They use an encrypted control frequency. 3. It is not against the law in your area. 4. you have a Trunked scanner. Following trunked frequencies requires a trunked scanner which is very different from regular everyday scanners. If the photo of your scanner is accurate then it appears you have Digital capability so that won't be a problem. You can go to Radio shack and purchase a book on Public Safety frequencies and Control Frequencies which will give you the proper frequency range but they will tell you nothing about Encryption on any Frequency. If you can not find a Control Frequency then you will not be able to track the hoping that is used in a trunked system. By the way, a Regular scanner runs about $50 where as a Trunked Scanner runs $150 to $200.
    Oct 16, 2010 | Uniden BC72XLT Handheld Scanner
    I cannot figure out how to program my scanner to the fire frequency.
    To program any known frequency into your BC72XLT, power the scanner ON, and then:
    1. Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears.
    2. Use the number keys and to enter the frequency (including the decimal point) you want to store.
    3. Press E to store the frequency into the channel.
    Notes:
    • If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency.
    • The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475.
    • When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning 2 seconds after the end of a transmission before scanning proceeds to the next channel. To turn the function off or on, press Func + Dly.
    • If you enter a frequency that has already been entered elsewhere, the scanner sounds an error tone and displays the channel that was duplicated. If you entered the frequency by mistake, press then enter the correct frequency. To enter the frequency anyway, press E to
    accept.
    4. To program the next channel in sequence, press E then repeat Steps 2 and 3.
    Need the full manual for your scanner? You can download/print it here:
    http://uniden.com/pdf/BC72XLTom.pdf
    For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
    www.RadioReference.com
    BillB
    Jan 16, 2010 | Uniden BC72XLT Handheld Scanner
    Moved to another county.need to know how to program my scanner to here
    hELLO THERE:
    Here is a extensive list of links to scanner codes acrost the UNITED STATES
    i REALLY HOPE THAT YOU FIND THIS VERY HELPFULL
    BEST REGARDS MICHAEL
    Scanner Frequencies Database of old scanner frequencies for thousands of cities across the country. http://www.cityfreq.com/ - 6k - Similar pages RadioReference.com - Scanner Frequencies and Radio Frequency Reference The world's largest scanner frequency and radio communications reference source,
    featuring a complete frequency database, trunked radio system information, ... http://www.radioreference.com/ - 17k - Similar pages RadioReference.com - Scanner Frequencies and Radio Frequency ... Scanner Frequency and Radio Communications Reference Database. http://www.radioreference.com/apps/db/ - 62k - Similar pages SCANNER FREQUENCIES - Online Database - Find Scanner Frequencies ... Scanner Frequencies Database, Police, Fire, Rescue, Racing Frequencies, Airport,
    Railroad, Taxi, Amateur Radio, Ham Radio Call Signs. http://www.nationalradiodata.com/ - 18k - Similar pages Scanner Frequencies & Codes Similar pages
    Nov 11, 2009 | Uniden BC350C Base Scanner
    Need Scanner Frequencies & Codes
    Hello there:
    here is a whole list of links that will get you what you need ok
    I hope that this is very helpfull for you
    Best regards michael
    1. Police Scanner Frequencies & Scanner Frequency Resources Police scanner frequency page where you can find scanner frequency resources from across the net U.S. including free and commercial databases and lsitings.www.police-scanner.info/police-scanner-frequencies.htm - Cached
    2. Police Scanners, Scanner Frequencies, & More Police Scanner Stuff! ... police scanners; general police scanner info, police scanner frequencies, live ... 10/03/09 - Police Scanner Frequency Resources (3 New Resources Added! ...www.police-scanner.info/index.htm
    3. General Radio Scanner Frequencies General Scanner Frequencies in subjects including police, fire, aviation, ... Until the day internet becomes free to all, that is something that just cannot be ...www.angelfire.com/wi/scanner/frequency.html - Cached
    4. The Nation's Oldest and Largest Scanner-Only Dealer Frequencies ... name and password for free (although donations are welcome) and ... Copyright © Scanner Master Police Scanners Corporation. All Rights Reserved. ...www.scannermaster.com/Frequencies_s/121.htm - Cached
    5. Scanner Frequencies * Scanner Resources Free Spies Online E-mail. Greetings by Spies Online. Library Articles. Link To Us ... will find police frequencies, general frequencies, scanner radio information and ...www.spiesonline.net/scanner-resources.shtml - Cached
    6. Scanner frequencies, police, fire, NASCAR, airport, Ham radio. Scanner frequency Spectrum database, including police, fire, rescue, racing ... Free US Amateur Radio Call Sign: Home. Scanner. Frequencies. Amateur. Radio. Mass Media ...www.nationalradiodata.com/help-frequencies-frameset.html - Cached
    7. free police scanner frequencies ? washington idaho montanawashington idaho montanaanswers.yahoo.com/question/index?qid=20081023025353AAVGPXU
    Nov 09, 2009 | Uniden BC92XLT Handheld Scanner
    Have a programable police/fire scanner and no local codes?
    Hello there:
    here is a couple of links that will get you to where you can find them
    1. Police Scanner Frequencies & Scanner Frequency Resourcessafe.gif Police scanner frequency page where you can find scanner frequency resources from across the net US including free and commercial databases and listings.
      www.police-scanner.info/police-scanner-frequencies.htm - Cached - Similar
    2. Police Scanners, Scanner Frequencies, & More Police Scanner Stuff!.avgnotice { width: 320px; font-size: 7px; line-height: 7px;}.avgimage { height: 7px;}.avgborder { border-color: #00A120; border-style: solid; border-width: 0 3px; font-family: Arial, Helvetica, sans-serif; font-size: 10px; line-height: 13px;}.avgsep { border-color: #C0A8A6 #C0A8A6 #FFFCF7 #FFFCF7; border-style: solid; border-width: 1px 0; font-size: 0px; line-height: 0px;}.avgtop { text-align: center; background: #F4FBF4 repeat-x url(chrome://searchshield/content/background_top_green.gif); padding: 0 5px; height: 30px;}.avgmiddle { background: #C3E5CA repeat-x url(chrome://searchshield/content/background_middle_green.gif); padding: 5px 10px; word-wrap: break-word; overflow: hidden;}.avgbottom { background: #00A120; padding: 10px 5px 0 10px; border: 1px solid #00A120;}.avgbottom td { font-size: 10px; color: #ffffff;}a.avgbutton { color: #0000ff; display: block; padding-top: 3px; width: 69px; height: 20px; text-align: center; background: no-repeat url(chrome://searchshield/content/click_here_green.gif);}.avgtitle { color: #00A120; font-size: 11px; font-weight: bold; margin-bottom: 8px;}.avgnote { font-size: 9px; font-weight: bold; padding-top: 5px;} --> Safe: This page contains no active threats. Explanation:
      It is safe to proceed to this page.
      Domain:
      IP Address: 207.217.125.50
      Owner:
         Name:
         Address:
         Country Code:
      Scanned on: 10/13/09 20:44:43
      (1.08 seconds to scan this page)
      Ratings are provided by AVG. Site owners please contact AVG Technologies for questions. Keep up to date with the latest AVG news and updates. Visit the AVG website.
      click here Get our most complete protection against online threats. Get AVG Internet Security today. Find out how. click here ')" id="XPLSS_389644331U1" src="chrome://searchshield/content/safe.gif" border="0" hspace="5" /> Find everything about police scanners; general police scanner info, police scanner frequencies, live police scanner feeds, police scanner websites & more ...
      www.police-scanner.info/ - Similar
    3. you can also go to police scanner live to get some local codes ok
    4. I really hope that this is verry helpfull
    5. best regards michael
    Oct 14, 2009 | Uniden Radio Communications
    Where can i get police frequencies for arkansas?
    Hello there:
    depending on what part of the state you live in this should help out a lot
    1. Central Arkansas Police Frequencies Central Arkansas Police. Benton Police. 154.580. Bryant Police. 155.565. 155.580. 154.680 new ... Shannon Hills. 37.220. Sheridan Police Dept. 155.640 ...www.skylord.com/kevin/central_police.html - Cached
    2. Northwest Arkansas Police Frequencies Northwest Arkansas Police. Bentonville Citywide Trunked System. 856.2625. 857.2625. 858.2625 ... Fayetteville Police Department 10-codes ...www.skylord.com/kevin/nw_police.html - Cached
    3. Arkansas State Police Scanner Frequencies and Radio Frequency ... Scanner Frequencies and Radio Frequency Reference for Arkansas State Police ... Arkansas State Police operations are conducted on this system. Frequency Display ...www.radioreference.com/apps/db/?aid=603 - Cached
    4. Arkansas Scanner Frequencies and Radio Frequency Reference Scanner Frequencies and Radio Frequency Reference for Arkansas ... Arkansas State Agencies. Frequencies for Arkansas public safety agencies. Choose Agency
    5. OK?
    6. best regards michael
    Sep 28, 2009 | Radio Shack Pro-95 Handheld Scanner
    Want frequencies for ''lower Burrell police'' pennsylvania
    Hello there here is the link for you ok?
    1. Scanner Frequencies Scanner frequencies for thousands of cities. ... Scanner Frequencies. Alaska. Alabama. Arkansas. Arizona. California. Colorado. Connecticut ...www.cityfreq.com - Cached
    2. General Radio Scanner Frequencies General Scanner Frequencies in subjects including police, fire, aviation, ... If you are looking for scanner frequencies, then you have come to the right place. ...www.angelfire.com/wi/scanner/frequency.html - Cached
    3. Police Scanner Frequencies & Scanner Frequency Resources Police scanner frequency page where you can find scanner frequency resources from across the net U.S. including free and commercial databases and lsitings.www.police-scanner.info/police-scanner-frequencies.htm - Cached
    4. Scanner Frequencies & Codes Get a scanner frequency database program by email for your state (Works with Scancat) ... Mr. Scanner Trunking Database You Can Export both frequencies and ...www.bearcat1.com/free.htm - Cached
    Sep 15, 2009 | Uniden BC248CLT Base Scanner
    How do i use an inherited uniden scanner. dad didn't leave instructions.... how do i set it up? which frequency do i use? many thanks
    A scanner, if used properly, can monitor frequencies as it progresses through them. If you want your scanner to monitor only certain frequencies of your choice, you can set those frequencies as the PRIORITY channels. Example: push PROGRAM then punch in frequency 152.6255 then set the mode (if nessessary) at VHF (very High Frequency) UHF (Ultra High Frequency) or FM (Frequency Modulator) or AM (Amplitude Modulator) etc. You can program as many priority channels as the scanner allows.
    Hope this helps!
    Jun 23, 2008 | Uniden BC72XLT Handheld Scanner
    Scanner frequencies
    almost all frequencies are going digital encryted which will make finding frequencies hard to find
    but there is a way to find frequencies
    goto internet type in police scanner frequencies ( your city state or town) this will find the frequencies you need
    Jun 14, 2008 | Uniden BC92XLT Handheld Scanner
    Radio Communications Logo
    24 people viewed this question
    Top Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a Radio Communication Expert? Answer questions, earn points and help others
