Question about Toro 53710 12-Inch Pop-Up Fixed Spray Shrub Sprinkler Body Only - Nozzle Sold Separately
Toro sprinkler head adjustment - Toro 53710 12-Inch Pop-Up Fixed Spray Shrub Sprinkler Body Only - Nozzle Sold Separately
How to adjust a toro mini sprinkler
Get your model number than google model number. They should have a set of directions to adjust everything from nozzle to the rotation of sprinkler
Jul 26, 2015 | Garden
Toro instructions
Follow the instructions from Toro.
Aug 09, 2014 | Toro 570Z Fixed Spray Sprinklers 3" Pop Up
Instructions to maintain a TORO TR50XT Sprinkler
The sprinkler head unscrews just like a bulb. Dig a hole around the head to below the connection.
Unscrew the old one and screw in another one. You might need a nopple on the new head to match the connection. Set up the new head with the same setup an the one in the ground before you unscrew it as water will come out of the pipe and fill the hole. You want to get the new head set before debris gets into the pipe.
Jul 05, 2014 | Toro TR50XT-HP, Adjustable Arc, 12 Inch...
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
How to adjust the spray pattern on the 570 series pop up
Change the nozzle. If it is an adjustable nozzle change it to a fixed spray with the desired radius. 1/4, 1/3, 1/2, 2/3, 3/4 patterns are available.
Mar 25, 2014 | Toro 570Z Pro Series Black Pop-Up...
Is there a video on programming a toro lawn master II timer
I have found these timers to be the most difficult for a homeowner to master. I suggest going to Toro's web site and downloading the operating instructions.
Sep 30, 2013 | Toro 53805 Lawn Master II 4-Zone Landscape...
Hunter sprinkler head adjusting...
I googled Hunter sprinkler heads and where to purchase them. In my area (the East bay, Tri-Valley) in Nothern California.
I went to Ewing Irrigation in Dublin, CA and found the Hunter sprinkler heads there. The man working the counter got two for me and he demonstrated how to change the head by unscrewing it from the base at or just below ground level by removing the old one and screwing in the new head. He also showed me how to adjust them with the spray pattern. You will need the little tool that comes with the sprayer head.
Making sure the center arrow is completely to the left and rotate the head to the right then back to left. They are set to a 180% spray pattern from the manufacturer. If you want a bigger pattern you turn the adjuster toward the ( + ) side and if you want less pattern you turn the adjuster to the ( - ) side. He showed me how to install the red sprayer inserts by simply pushing them in the cavity making sure the little u shaped indentation is pointing up to allow for the set screw to go through to adjust the spary.The spray varies in distance and amount of water being emitted from the head depending upon the insert used.
I was able to replace the Hunter head, adjust the spray and changed out the insert a few times until I found the one I liked. I used needle nose pliers to remove the initial spray insert that the man @ Ewing installed until I found the one that worked best.
I found using needle nose pliers makes it very easy to grasp the little inserts for replacing.
-Terry
Apr 04, 2008 | Ace Hardware Hunter& Low Profile III...
Toro 53710 12-Inch Pop-Up Fixed Spray Shrub Sprinkler Body Only - Nozzle Sold Separately Logo
44 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
