Question about Amana AP076E Portable Air Conditioner
Blowing Alternating cold air and hot air from unit
I have an Amana AP076E Portable air conditioner. I put it on air condition mode running at the lowest temperature 61 degrees. The air that comes out is very cold but then it will suddenly switch and blow hot air out. The air conditioner will alternate blowing out cold air then hot air. I do have the air exhaust connected and it does have hot air blowing out to a window. Please advise.
5 Suggested Answers
  • 34 Answers
SOURCE: blower motor not blowing
you will have to replace the blower motor
Posted on Aug 12, 2009
Sparky2012
  • 102 Answers
SOURCE: my ptac is not blowing hot air only blows warm air
freon is low or outside is very cold
Posted on Dec 04, 2009
  • 82 Answers
SOURCE: Manual for Amana AP076E portable a/c
The manual is by Haier but you will see it is or the Amana AP76E. - http://service.haieramerica.com/documents/User%20Manual%20AP076E.pdf
Posted on May 11, 2010
Testimonial: "Great job!!"
SOURCE: Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Posted on Feb 18, 2011
I need a manual for portable A/C Technitrend TN09E
Stick it in a bowl of rice leave it overnight then take it to an iPhone repair place if the rice seams infective
May 15, 2014 | Amana AP076E Portable Air Conditioner
I have a Haier air/heating unit. The heat has stopped working.
Keep heating mode and temp setting at minimum 3 to 4 degree C* between room and required temp.
If still not working, replace the heating sensor.
Tnx
Nov 13, 2013 | Honeywell ER150B Air Conditioner
Ac repair portable 12000 btu unit will not blow cold air
Maybe you have it set on dehumidifier mode instead of air conditioning mode. That happened to me with mine too. And turn off your timer (if it has one) or it will shut off after a while and you will forget why.
Jul 23, 2013 | Amana Portable Air Conditioner
Doesn't get cold
be more descriptive there are several things that can cause it not to get cold.
Aug 31, 2012 | Amana AP076E Portable Air Conditioner
THE UNIT BLOWS COOL AIR OUT THE FRONT BUT HOT AIR OUT THE BACK THE MODEL IS aP076E .i DO NOT HAVE A MANUAL BUT IT DOES NOT SEEM TO BE REAL HARD TO RUN THANKS
Yes, that is the way a typical air conditioner works. The portable types need to have the hot discharge air direct outside via flexible hose and an adjustable window bracket. The window closes on the bracket to create a seal, and the hose connects between the air conditioner discharge and the opening in the bracket. This is called "venting". Most portable air conditioners include (or offer as an accessory) a "vent kit" or "window kit".
Some portable air conditioners do not provide a way to vent - fortunately yours appears to have a kit for this purpose. You may wish to check out this page on venting. It has plenty of ideas and suggestions for venting. This site has some very good pictures to document making a vent - and is worth a look, too.
If this was helpful, please rate it "4 thumbs up" - thanks!
Aug 02, 2011 | Amana Heating & Cooling
HOW DO I GET AN OWNERS MANUAL
Please check this link and see if you get the specs.
www.portableacguide.com/unit/?Amana-AP076E
Sep 26, 2010 | Amana AP076E Portable Air Conditioner
I have an amana self evaporating portable ac for my 500sf condo. I have had to unhook it and roll it outside 4 times to drain it. Lately water is now spilling out the back vent on to my floor. What's the...
It appears to me that because of the small size of your condo, you are just recirculating the humidity in the apartment. The unit is condensing the moisture in the air and then reheating it in the pan causing it to evaporate back into the air. The unit is working properly but the humidity level in your apartment continues to rise. You really need to add a drain from the pan of your portable air conditioner.
Jul 20, 2010 | Amana AP076E Portable Air Conditioner
Need instruction manuel for amana AP076E
ManualsLib has the manual here: https://www.manualslib.com/manual/5170/Amana-Ap076e.html . Click on the Download button and follow the instructions there if you do not want to go through the manual page by page.
I hope this helps.
Aug 29, 2017 | Amana AP076E Portable Air Conditioner
Amana AP076E Portable Air Conditioner Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
