Question about Konica Minolta Office Equipment & Supplies
Bizhub error code c-255c - Konica Minolta Office Equipment & Supplies
3 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: error message when accessing internet explorer on the computer
This happens on installing vista the first time If u can install despite this message(ignore), then restart in safe mode and if your Vista is genuine then ask microsoft to send this particular file(SHELL32 if I h'nt forgotten) replace where the original is supposed to be and after that it should be fine. The Only other option is to Install WinXP_SP3 & enjoy.....sodeep
Posted on Mar 20, 2009
jennifer720
  • 830 Answers
SOURCE: hi I have error message
You can remove the Dell support from your add/remove programs. This support is installed on all Dell systems in factory. Once your warranty runs out, it is pretty worthless because you still have to pay for support.
Go to start, control panel and click on add/remove programs.
Look for Dell Support or help and uninstall it. Reboot computer and the error message will go away!
Posted on Oct 21, 2009
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Error code 255c
T reset the code , open close the front door. The code is stating your Black image unit, sensor is bad, first replace the black image unit, if not that then there is sensor that will need to be replaced
May 21, 2014 | Konica Minolta bizhub C250 All-In-One...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Bizhub 211 error code c500
ihave error code c5oo c501 in bizhub 211
Jan 16, 2013 | Toshiba E-Studio167 Copier
Error code f-26-3
the bizhub 222 typically does not not throw this error code this is an error code is for one of the older konicas and is a toner density error code check developer/ developer unit
if this is a bizhub 222 the toner density error code would be c2557
May 10, 2012 | Konica Minolta Bizhub 222 Black and White...
Hi I have error message file:///C:/Program%20Files/Dell%20Support%20Center/sscommon/common/snapins/shell/ss_shell.htm?config=..%255c..%255c..%255c..%255cgs_agent% how to solve the problem
Oct 21, 2009 | Dell Inspiron 530 Desktop Computer
Error message when accessing internet explorer on the computer
Mar 20, 2009 | Dell Inspiron 530 Desktop Computer
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
119 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
