Question about Frigidaire FRS23R4A Side by Side Refrigerator
Ice maker The Ice maker is making a loud sound (kind of like a motorcycle. The only way I could get it to stop was to unplug the fridge. What can I do to fix the problem?
  • 291 Answers
Couldnt bring up your model #... should be a off / on switch or arm to raise, should be able to shut off your ice maker... cant imagine what could be making a sould like a motor cycle lol
Posted on Aug 29, 2007
SOURCE:
Could some please post how to remover the ice maker from my kitchen aid model ktrc 19 m refrig thank you
Look right above the icemaker part that forms the cubes. Its usually brown in color, Just above it are 2 extensions of that brown part that has 2 screws going into the left side of the freezer, Remove the 2 screws and the unit comes out. The power plug for it is just to the back bottom of the ice maker. If you can see it you can probably just unplug it to stop the noise.
Apr 11, 2015 | Refrigerators
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
My ice maker is making a loud noise
MOST HAVE A PLUG OUT OF THE I/MAKER,JUST BEHIND THE I/MAKER,JUST UNPLUG IT THERE..FRED
Feb 14, 2010 | Refrigerators
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Sep 09, 2009 | Samsung RS2630WW Side by Side Refrigerator
Buzzing sound clicks on and off from underneath fridge
that would be your relay going bad it will stop the fridge all together change it to a 3 and 1 relay
Apr 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Nov 17, 2007 | KitchenAid KSCS25IN Side by Side...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
309 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
