Question about Samsung Remote Control DB93-03012B p/n:DB9303012B
PROGRAMMING SAMSUNG AIT CONDITIONNER WITH REMOTE CONTROL
HOW TO GET THE RIGHT CODES AND THE PROCEDURE FOR REPROGRAMMING FROM THE REMOTE CONTROL ALL THE LIGHTS OF THE INDOOR UNIT ARE BLINKING REFERENCE OF REMOTE CONTROL: SAMSUNG DB93-03012B
5 Suggested Answers
  • 13433 Answers
SOURCE: Sensor in my Samsung Split
The receaver is most likely broken?
Posted on May 24, 2008
  • 250 Answers
SOURCE: THE MONITOR OF INDOOR UNIT DISPLY ALL THE
This could be caused by a blown circuit breaker or fuse inside the unit, a damaged compressor or fan motor, faulty wires connecting the compressor or fans to the control board unit, a faulty or hung relay on the control board (this can sometimes be solved by tapping the relay with a screwdriver), or the starter capacitor for the compressor or fan motor.
Posted on Sep 20, 2009
SOURCE: indoor unit light blinking ( first n second light from top)
I have the same problem too. Aircon cannot switch on, two lights from the top is blinking. Everytime I turn on, the flip is open then close again with sound. The technician said the thermostat cable need to be replace. It cost about $15. The cable is 14" long. Hope this help.
Posted on Apr 09, 2010
hvac1960
  • 2133 Answers
SOURCE: when i start the a/c indoor unit working and after
Green blinks indicate communication to outdoor, but red light indicates communication problem. Check PCB.
Posted on Oct 27, 2011
Uei remote control codes for Samsung tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Feb 18, 2017 | Samsung Televison & Video
Tip
Do it Yourself: Reprogramming the Remote Keyless Entry (RKE)
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Jeep Grand Cherokee Alarm System (1993-1998)
I would try reprogramming the Remote Keyless Entry (RKE) transmitters before looking for anything else. Make sure the batteries in the RKE transmitters are good and replace them if in doubt. Here's the procedure for programming the RKE transmitters.
Up to 4 Transmitter Identification Codes (TIC's) can be programmed into the receiver at any given time.
1. Open the driver's door of the vehicle. Leave it open through the programming procedure.
2. Move the mechanical door lock lever to the LOCK position.
3. Insert the ignition key and turn it to the RUN position.
4. Turn the ignition to the RUN position. Within 20 seconds, aim a transmitter at the receiver dome and press the lock button, for at least 5 seconds. Once the receiver accepts the programming code the driver's door will unlock.
5. Once the first transmitter has been programmed, additional transmitters (up to 4) may be programmed into the receiver. Within 20 seconds of the previous transmitter programming, move the mechanical door lock lever to the Lock position. Aim another transmitter at the receiver dome and press the LOCK button for at least 5 seconds. The door lock will cycle again.
6. To lock the programmed codes into the receiver, the ignition must be turned off and back on within 20 seconds after programming the last transmitter's code. At that time, all previous codes are erased from the module.
If the alarm still doesn't work correctly, you probably have a bad Alarm Module. If you wanna download this procedure, clic the image.
Enjoy Jeep.
on Sep 23, 2009 | 1993 Jeep Grand Cherokee
Need code for samsung tv remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Sep 18, 2016 | Samsung TV Remote Control
How to use a bp59-00048c samsung remote control
Programming Notes
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. ..
Sep 02, 2016 | Samsung Televison & Video
REPROGRAMMING MY UNIVERSAL REMOTE
Programming Notes
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts..
Jul 24, 2016 | Conect It RM500 Multi-Brand Universal...
I have a Samsung bn59-00516a remote control how do I get codes for a Lg lcd TV, 32lx2r and use the Samsung remote as I don't have a manual
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Programming Notes
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
Apr 24, 2016 | Samsung Televison & Video
How can I get my Samsung blue ray dvd player to work by using my Samsung tv remote?
Programming Notes
Apr 18, 2016 | Samsung TV Remote Control
Where can I view the remote control for a Samsung LED TV 32" series
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
Feb 15, 2016 | Samsung Televison & Video
Remote key fob will not work-battery replaced
VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Remote Control Erasing (1997 ON)
Procedure
key.
3. Press the remote control unlock button 5 times in 1 second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory
erase.
5. Switch ignition OFF, all remotes are now erased.
Dec 24, 2008 | 2004 Volkswagen New Beetle Convertible
Programming RCR311 universal remote to samsung tv
RCA Universal Remote Control-Programming Codes
Try chicking on the web page above and see if this helps. Good Luck.
Ed
NC Electronic
Mills, Wyoming
Jan 25, 2008 | RCA RCR311B Remote Control
Samsung Remote Control DB93-03012B p/n:DB9303012B Logo
37 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
