Question about magicJack New & Improved 2012 Plus Free 1yr Subscription Magic Jack
Magic jack does not work i have dish net satelight
When i first got stelight my magic jack worked now dose not i had work done on satelight and it stoped
Why does a CS6124 not work with Magic Jack?
that phone should work with magicjack , you are not getting a dial tone because you are no setting it up right somewhere along the line ,
Dec 10, 2014 | VTech Communications Cs6124 Cordless Phone...
Magic jack contact number
First is your internet connection working Ok? If so then unplug and remove any software from your machine. Next plug it back in. It should act as a new install. Lucky you upgrade then should come up. If not go to http://mjcheck.low.li/ and download the firmware. It will have to restart but should work after that. If not repost. good luck.
Happy MJ user
Mar 17, 2014 | Computers & Internet
I bought a magic jack plus my old magic jack broke I pluged the new one all my contacts came back but I can only receive calls but I can not call out
Lets try this. When you installed your new magic jack, did you install the new software from the website, or did you just plug it in and go "HEY all my peeps are here. We are done?" Install the new software from magic jacks site and if you did this then and it still doesn't work, then i am out of ideas for this one. Only other thing i can think off is in your settings and you have it on incoming calls only.
Mar 15, 2014 | magicJack Plus Pc To Phone Adapter
FAX MACHINE WILL NOT WORK WITH MAGIC JACK
Magic Jack will work with fax machines. You may have to experiment by slowing down the fax machines modem transmits speed. This is done in the machines menu.
The Magic Jack manual is quite clear, it can handle faxing.
Mar 21, 2010 | HP 640 Inkjet Fax Machine
My phone was working well, every time I plug into my computer, BROKEN STORAGE shows up on. I have brought several different magic jack, thinking it was the magic jack itself.
If you've already gone to magic jack's website and downloaded their updated software then you're looking at a jack reformat. I've had this problem several times with my magic jack and you'll find many different solutions that just don't seem to work and are all very involved. Warning: doing this will lose all your contacts which from my experience is the only way to go to get this problem fixed...and only temporarily mind you until the problem happens again. Keep your contacts elsewhere in the meantime. Go ahead and go to your "My Computer" from your start menu and then take a look at the drive letters that come up while you have the magic jack plugged in...if you try to open them you will notice that one of them will say that the drive needs to be formatted (magic jack creates 2 drive letters for the device) If you see that, go ahead an select yes to format it and doing a quick format with all the default selected options will do the trick. Once it's done formatting, Launch the phone application and you would get to the screen where it asks for your email and password and then you will be logged in. keep this solution in mind whenever it happens again~ Good luck.
ASpecialty4You.com
Dec 11, 2009 | Lands Phones
Calls cutting out with magic jack
Your ISP connection speed may be inadequate. Typically, the upload speed (outgoing voice) is much slower than the incoming speed. To check majicjack recommends that you test your system on http://www.speakeasy.net/speedtest/ .
It's also possible that your internet provider is purposely delaying the outgoing latency in order to discourage VoIP that THEY don't provide. I think this is (or at least should be illegal) but in any case a complaint to the FCC might be in order.
Aug 23, 2009 | Computers & Internet
Need to find fax machine thats compatable with magic jack
Magic Jack is digital, fax machines are analog....it won't work.
Mar 02, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Changing computers upload settings
Hey, I sent you a clarification reguest in which I requested you to run a speed test at www.speedtest.net and report me the results it gives you. seems it was removed.
Then we can move on and see what can be done about it.
Sep 01, 2008 | Dell Inspiron 1200 Notebook
Open Questions:
See all magicJack New & Improved 2012 Plus Free 1yr Questions
magicJack New & Improved 2012 Plus Free 1yr Subscription Magic Jack Logo
80 people viewed this question
Top magicJack Cell Phones Experts
gaucherre
David Payne
David Payne
Are you a magicJack Cell Phone Expert? Answer questions, earn points and help others
