E4 error code
SOURCE: Bosch Nexxt Washer Error Code E02
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
SOURCE: BOSCH WFMC3200UC WASHER
Go to http://www.repairclinic.com/SmartSearch/smartsearch.aspx and type WFMC3200UC under search at top. Then select gasket/seal/o-ring from part type drop down menu.
SOURCE: error E04 on bosch nexxt wfmc32000c
Bosch E04 Solution:
SOURCE: error code 02 on a newly installed Bosch Nexxt Washing machine
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
SOURCE: Bosch Nexxt Premium WFMC6400UC washer has error
Sorry to hear you`ve been stuck so long. The first thing to do is get any water out which may still be present.
As for the problem you`ve described, typically what this really means is an obstruction/debris inside the drain pump, specifically the button trap/lint filter insert preventing the unit from spinning or draining properly.
You haven`t mentioned whether you`ve checked the pump or not, so I`ll assume you didn`t. This is how...
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
The error code should be gone when you restart a cycle however, if the error return`s you`ll need to check further for blockages in the drain hose, or the bellows from the tub to the pump.
Ultimately you could have a faulty control, but not very likely.
Hope this help`s. Thank you for visiting "fixya", please take a moment to rate the solution provided here accordingly.
Let me know if you require further assistance. Good luck.
macmarkus :)
Testimonial: "thank you very much for the advice!!! we were able to open the washer' however the buttons are not working and the error message stays "
