Question about Sony FD Trinitron WEGA KV-20FV300 20" TV
24 inch coby flatscreen 1080p
My television will not change channels it is stuck on channel 11. it also does not have a controller how can i fix this ?
  • 87 Answers
SOURCE: Television stays on one channel
You likely have bad solder connections in the tuner.
Posted on Jul 13, 2007
jerryg50
  • 1689 Answers
SOURCE: TV stuck on Channel Fixed;6
Go in to the user menu and find where the Auto Channel Setup is located. You can consult the instruction booklet for your TV set. Try this and see if it works. If it does not then there are a number of areas in the set where there can be some defective components.
The tuner is controled by the uPC system. There are a number of interface circuits involved for the channel control. Problems in these areas can cause the channels to not be able to be changed.
Jerry G.
Posted on Jan 17, 2009
TVtechmaniac
  • 140 Answers
SOURCE: Ghannel Fixed:3
Go to the on screen menu, select the third option from the left "channel setup"(CH), scroll down to "channel fix" select it and turn it "off".Exit menu and you should fix the problem.
Posted on Jan 29, 2009
SOURCE: Sony KV-20S40 stuck on channel fix
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Posted on Apr 21, 2010
SOURCE: Sony Trinitiron 27 inch. It's stuck on channel 27
go to menu then channel turn off channel fix that might help ya
Posted on May 31, 2010
How do i give my tv an hdmi channel? Do i have to buy a hdmi cable? and if I do which cable? I want to use an xbox one but It won't show due to me not having an Hdmi channel so I was wondering howican
HDMI is a data protocol and includes the associated ports and cables it is not a channel. If Your TV Does not have an HDMI port you can use a converter to change it To a connection your TV Does support. Be aware a cable with the appropriate ends is not the same as a converter...a converter changes the language to something the tv can understand.
Jul 30, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
Hi, I have this TV that i love, recently i see the picture is bigger and i cant see the subtitle and or words around picture like Channel name or ads running below picture
See page 24 of the included manual The view mode button is just above the channel change button. The manual shows how the screen will zoom etc as you right size the view for you. I've included an image of page 24 in the event you can't read the PDF file.
It is east to mis the channel scan and not realizing it change the aspect ratio
I hope that this helps.
https://content.abt.com/documents/37621/LC60LE830U_manual.pdf
Jan 10, 2016 | Sharp Aquos LC40LE830U 40-inch 1080p 120Hz...
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
Why doesn't the remote control work?
The batteries may have to be replaced. If new batteries do not solve the problem, it may be necessary to replace the remote.
Jul 16, 2015 | Coby Televison & Video
Need a manual for v-zon 1900
I have an impression vzon tv's might be rebranded Coby tv.
Otherwise it is hard to find any documentation online for the Vzon. Please try this manual out. Scroll down to the download link once you get to the link below.
Coby Instruction Manual LCD FLATSCREEN TELEVISION TF TV1901...
Aug 29, 2014 | Coby Televison & Video
Black bar in one of the channels
Probably closed captioning is on.
May 02, 2010 | Televison & Video
ILO 26HD television flat screen won't change channels/stuck on 11
Try doing a channel scan or autoprogram of the tuner again. This should fix the issue.
Nov 11, 2009 | Televison & Video
Cannot turn tv off with power button or remote , must unplugpower
It could be a stuck button on the set. check to make sure they all feel the same.. If one don't feel right try to free it .. If a button is stuck it wont let any of the others work or the remote.
Mar 29, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Coby televsion
Hello, make sure you go into the settings and do the channel scan on Cable or whatever signal your using. If you can only get channels 2-9, press the -/-- button on the remote, until you get 2 digits, then you can access double digit channels.
Dec 20, 2007 | Coby TF-TV1901 19 in. LCD Television
Sony FD Trinitron WEGA KV-20FV300 20" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
