Where to buy quality pinch rollers for Nakamichi CR7 tape deck?
robotek
  • 1512 Answers
SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Posted on Dec 09, 2007
SOURCE: teac x10r tape recorder
If the tape transport doesn't move up on play, but you can push it up and pull it down by hand, the grease on pivots is all dried up. you can take it apart and clean it. replace belt while your at it.
Posted on Dec 31, 2007
  • 319 Answers
SOURCE: Nakamichi BX-125 Cassette Deck
Check leaf switches and also, press play -- after a few minutes, feel motor(s) for heat build up. If it gets hot, either motor is bad of something is preventing it from rotating
Posted on Apr 25, 2008
VOTIT
  • 2071 Answers
SOURCE: deck A won't turn
the problem is the clicking spring of the pinch roller,that pushing through the spindle,maybe is weak or is not there,try to find out inside the deck,if you cannot find it.Improvised a clicking spring by means of the string of the guitar number 00,is good of making spring.
Posted on Jun 14, 2008
robotek
  • 1512 Answers
SOURCE: JVC KD-85 Cassette Deck Stops in Seconds in play, REW., & FF
Hineovision1
The deck will need new belts and idler drives cleaned and serviced, and perhaps some idler tyres replaced. You can get a belt kit from these guys. replacing them is not such a difficult job if you have some mechanical aptitude. Just take it slowly, and focus on getting the transport out of the unit.
I am more than happy to answer any other questions you may have aboutit, please get back to me here, or use the ASK function to go straightto me :) If you are still unsure, have problems, or we need to look atthe situation more deeply, then before you give a rating for thisadvice, hit the ASK buttonThanks for using FixYa, If you consider the advice I have given you assound, a FixYa rating is a great reward for my efforts to help you.Cheers.
regards
robotek
Posted on Jul 08, 2008
Looking for the black knob on the deck that the tape runs under
The pinch roller is what it is called. The tape is pinched between it and the drive motor axle. We need to know what the make and model of the unit is.
Mar 08, 2015 | Audio Players & Recorders
I have a piece of broken tape stoch in the transport mechanism. I have carefully taken out several bits but it still defaults to stop immediately. Any body got any ideas. Perfect condition otherwise
Tape remnants could be wrapped around the capstan or jammed in some hard-to-see location. If there is an end of tape sensor, it may be blocked.
Oct 26, 2014 | Audio Players & Recorders
Ad-f410 change pinch roller
Why do you want to change the Pinch Roller? Most of the time they just need a good cleaning and other things in the deck like back tension checked. Pinch Rollers are only changed if they are cracked and I have seen few cracked Pinch Roller in 40 years.
May 02, 2014 | Audio Players & Recorders
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
The capstan drive roller on my tape deck fell apart. Spindle is .0975" dia. Pinch roller is .862" dia. All other belts and rollers seem OK. Where can I find a replacement capstan roller? Thanks.
You need to locate the supplier of pinch rollers that will fit your tape deck. If that fails, you have a useless piece of gear. If the unit is of decent quality, you should be able to locate a supplier. You didn't include the make or model, so good luck.
Oct 06, 2010 | Audio Players & Recorders
I purchased a Nakamichi 480 tape deck from a seller on eBay. All the push buttons work OK except for the EJECT button. It will not allow the compartment to open where you insert a tape. The eBay seller...
Hi there
It is probable that the head assembly or pinch roller assemblies are not returning to their correct rest position. The arms that carry the pinch roller assemblies develop dried grease problems in the bearing/post they are mounted to that prevent their timely return and fouling the casette shell preventing eject. Check them by seeing if they are clearing the cassette shell, and are "sprung into the home position with out binding.
I have repaired scores of these decks over the years, and am happy to talk to you more about the problem. Thanks for using FixYa.
regards robotek
Jul 02, 2009 | Nakamichi Audio Players & Recorders
Need pinch roller support pins for the Dragon cassette deck
Hi davejann
These guys can certainly help you with parts for older Nakamichi decks. They are in the UK, and have most parts for pre 1996 tape decks from the legendary makers. The synthesis chassis had dramas with pinch rollers siezing up from dried grease. I always used to strip and relube, and often replace the pinch roller/tape guide assly. Hit them up, if you have any dramas, get back to me here.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
May 27, 2008 | Nakamichi Audio Players & Recorders
Nakamichi BX-125 Cassette DEck
Unit probably needs belts. Over time, belts may become slack or decompose into tar-like compound. In this case, the deck will need to be cleaned and belts replaced. Take to pro/tech
Apr 16, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
