Question about Refrigerators
Ge profile refrigerator manual
We have a French Door GE Profile Refrigerator, Model # PFSS2MIYA SS. Fruits and vegetables freeze in the fresh produce drawers. Also, in the freezer the drawers keep sliding out and plastic parts fall off. Please advise what we need to do. We do not have an owner's manual and would like to have a parts manual too. Can you send us one?
5 Suggested Answers
  • 1073 Answers
SOURCE: GE Profile French Door bottom
IT IS STILL UNDER WARRANTY call ge at 800-386-1215 for factory service
Posted on Apr 15, 2008
BMT60
  • 126 Answers
SOURCE: My GE Profile Performer refrigerator is freezing fruits and veget
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
Posted on Apr 24, 2010
  • 2468 Answers
SOURCE: GE profile side by side
you need to check and see if the plastic flapper on the damper vent door has frozen open and broken,you need to remove all the air flow parts to check this physically,you can run the diagnostics,and hear the damper motor run,but if the door is broken and stuck open you cant see this without removing the plastic grill covers and all the plastic parts from in front of it,even where the light bulbs are located in the roof of the refrigerator,if this isnt it,then you may have bad thermistors in the side of the refrigerators walls,the diagnostics will tell you this in a pass/fail test,g.e. has had a problem with these damper doors though in the past
Posted on Dec 03, 2010
  • 5370 Answers
SOURCE: We have a 3-year old
The ventilations in the drawers are getting blocked.I will explain.When the unit starts,the freezer section starts cooling.When the freezer section gets cooled properly and reaches its regular temperature,then thermostat in the freezer section detects it and after this defrost procedure starts.In defrost procedure the fan in the freezer section starts running and the cool air from freezer section pass to the fridge section bu the ventilation drawers.And thus passes in all the sections.But in your case the cold air is passing to the vegetable and fruit section,but its not going to the other sections.The cold air is entering the section but its not going anywhere,just remaining there.So this parts are getting over cold.So in this case,either the defrost is not working or the coils are over frosted in the freezer section.And this causing the problem.But first try defrosting the blocked ventilation by manual defrost procedure.--------------
The defrost is not working or the evaporator coil in the inner section of freezer is got blocked by ice .
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.You can get the required parts from online sites like:--- www.repairclinic.com or from searspartsdirect online site.---------This will help. Thanks. Helpmech.
Posted on Jan 02, 2011
GE Profile SS refrigerator Handle is off on one end.
the screw must have fallen out they are small allen screws that hold it on
Jun 11, 2010 | General Electric PFSS5NJXSS Stainless...
Apr 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
Too cold
If the unit seems to be running non stop, you may have a bad cold temp control. If you have ice cream in freezer, it will likely be rock hard, that you need a chisel to scoop. if your ice cream is ok, its likely not the temp control. On your GE, in the fresh food section, do you have a canopy on the ceiling of fridge, and likely covers the whole top back portion of your fridge? If you do, there is a damper door inside, that breaks off its hinge, and stays wide open, allowing cold air from freezer to constantly be pulled into fridge, freezing food. If you do have this canopy, it will need to be replaced, as you cannot reattach the damper to its hinge.
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Apr 11, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Ge profile built in SS refrigerator
Go to www.geappliances.com - service and support section - parts and search for your model number . You will be able to get an exploded diagram in pdf format for each section of the appliance.
Graham
Nov 21, 2008 | GE Profile¿ 48" Built-In Stainless...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
