Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washing machine
F-02 code Want to check the pump filter. How do I get the face plate off? I got the 3 star shaped nuts off, but can't pull the front plate off. Muscles? Thanks, Scruffy66
PULL DOWN HARD, IT JUST TAKES SOME PERSISTENCE. kd
Posted on Sep 03, 2007
How can I unlock my Whirlpool duet washing machine?
Probably something stuck inside drain pump or pump is defective. Unplug machine. Take filter out of Pump to see if there are any obstructions. After you get pump issues fixed, plug back in and door should unlock.
Nov 01, 2017 | Whirlpool Washing Machines
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How can fix f 02
whirlpool duet f02 codeHow to fix fo2 fault code on a whirlpool duet front load washing machine, The whirlpool duet is one of the machines that have a main computer control that operate and monitor the functions of the machine,
This control is usually mounted behind the front panel,sometimes at the back or to the side, it also has a speed control board that is mounted on the bottom usually at the right side.
Whenever a problem accur there is a fault code displayed on the machine, there is a technician sheet with the fault codes on the machine, the technician can use this guide to go directly to the problem,
This f02 code mean there is a problem with the drain, there is a drain filter that sometimes get clogged with lint and other things,
Removing the kick plate and removing the drain access on the pump will reveal the drain filter, use a small bucket, and towels to catch the water that will be in the pump
Nov 26, 2012 | Whirlpool duet Washing Machines
Won't spin, code F 02
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Water will go everywhere so be ready. You need a nut driver to remove 3 screws that hold the service panel.
Video how to
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washergets a code 2 when it gets to spin cycle.wont rinse and spin
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have the front loading duet washer. The code F
F2 indicates a long drain usually caused by blockage in the filter, remove and clean out filter.
Also Check the drain hose and make sure it is not plugged or kinked.
If the above does not correct the problem, replace the pump
www.appliancehelponline.com
Apr 09, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have error code of f 02 showing up on my duet. It is not finishing spin or drain cycle?
display.
or kinked.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
2 minutes before the cycle ends, the whirlpool duet starts beeping and water was all over the place.it displayed at F 02 error.
Hello there. You most likely have a clogged pump.
There is a kick plate underneith the door and below that plate there are 3 (hex) screws.
Once you take the plate off, there should be a filter right before your eyes.
Whirlpool makes it easy to access it. Clean the filter and I think you'll be ok.
Try that first before you spend $79 on a service technician. Here is a picture of how it should look: http://www.flickr.com/photos/21558886@N00/2710225237 Thanks for your inquiry and using fixya. Hope this helped :)
Aug 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet. Strange noise and F 02 error code
  • If the above does not correct the problem, replace the pump.
Feb 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Marvin
Marvin
jimorris77
