Question about Garden
Honda GCV 160OHV cover oil leak
I have a Troybuilt self propelled with a Honda GCV160 engine. There is an oil leak from the OHV cover. I removed the 4 bolts but the cover wouldn't come off. I looked at engine diagrams and there is no gasket shown. Are they sealed with "Form-a-Gasket? Will I need to destroy the cover and replace it in order to fix the leak?
SOURCE: Leaks oil looks like from valve cover
You have to remove the spark plugs cables and remove the four nuts that you see when the cables are removed.
When the four nuts are removed, simply raise the valuve cover. When replacing the gasket, make sure you get the gromets as well. Those sometimes get worn or crack since they are more exposed than the value cover gasket. Make sure that you clean the cover from oil and replace the gasket with no use of silicon.
Good Luck.
Posted on Aug 04, 2008
  • 271 Answers
SOURCE: Valve cover and Oil pan bolt torque
Inside to outside for torque pattern, 7 foot lbs. or 144 inch lbs.
Posted on Oct 24, 2008
  • 11 Answers
SOURCE: Self propelled function does not work
hello
chek drive cable is not broken or come loose or drive belt as come off or broken
if these are okay then take off and check teeth on the drive wheels
hope this helps
Posted on Mar 15, 2009
  • 11 Answers
SOURCE: how to remove valve cover gasket on a 1998 honda accord
try removing the bolts hold on the valve cover and once you do that take a razor blade and a little lube and careful scrape the old one off.
Posted on Mar 24, 2009
  • 260 Answers
SOURCE: Motor Oil leaks from 1999 Honda Civic EX
make sure they are tight
could be time for head gaskets
make sure the old gasket from the old filter came off the block sometimes they come off old filter and stick this causes a leak due to improper seal.
Posted on Apr 10, 2009
Honda gcv 160 engine
Does this unit have an electronic fuel shutoff on the bottom of the carburetor?... If so, that is your problem. Otherwise, you will need to remove the carburetor, service it..
If u want test it first... Spray some carburetor cleaner into the plug hole then reinstall the plug. Start the engine, if it runs for a few seconds, u definitely have a fuel issue, carb....
U can buy a rebuild kit for the carburetor.
Also, go to you tube and search, how to service a 4 cycle carburetor..many videos to learn how...
Good curbside find!!
Oct 25, 2015 | Husqvarna HU700FH 22-in Self-Propelled...
What are the steps to start mower.
I could not locate your exact model for a manual. This machine's manual is very similar. Please read the operating and "How To Start" instructions inside the manual. They can tell you better than I.
http://lawnandgarden.manualsonline.com/manuals/mfg/yardman/120874r.html?idRes=11171312
Sep 11, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
I need to change oil in my yard man lawn mower. Where is the drain plug? I need to change the oil
Hi, you drain it out of the dipstick filler hole by tipping the mower to that side. Remove the sparkplug cap first as a safety precaution. Hope this helps, regards Phil.
May 17, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
How do I put the belt back on my Honda gcv 160 self propelled lawn mower?
Hi bairboys,
Here is a link for your owner's manual: http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_532430880.pdf
The instruction and belt diagram are on page 13.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Husqvarna 7021RH 21Inch 160cc Honda GCV160...
I have a Troy Bilt mower w/ a Honda engine GCV160. OK, so I turned it on it's side after the last mow and the next time I tried to start it, it smoked and quit. Now the engine will not even turn over when...
Pull the spark plug and see if there is oil in the cylinder. When you turn a 4 cycle engine over or on it's side, the oil can leak into the cylinder. There may be so much oil in there that the piston won't move. When you have the plug out, clean it before you re-install. Good luck...Lee
Nov 01, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Honda Self-Propelled Lawn Mower leaking oil?
It is toast you fried the crank/connecting rod, by running it low on oil.
Its hard to say what caused the oil leak, but now it is ruined.
Aug 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Jun 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
