Question about Garden
Snapper 7800190 what type of engine oil use
3 Suggested Answers
sawdust46694
  • 398 Answers
SOURCE: How much oil should my snapper rear engine 14 hp
The way i would do it. get 2 qts drain and flush oil out of engine. put the drain plug back in. remove the fill plug and fill with oil. i fill mine to the first thread under the fill and ckeck plug hole. keep the rest for adding if required.
Posted on Aug 30, 2009
  • 6468 Answers
SOURCE: Cannot locate the Primer button Snapper model 7800190 mower
some of the newer mower don't have one
Posted on May 16, 2012
Snapper ps90 lawnmower to change oil how much oil does it take
https://www.snapper.com/na/en_us/support/faqs/browse/how-much-oil-does-a-snapper-mower-take.html
Here is the Snapper web site. depending what motor you have depends on the brand
Cheers
Sir John Dana Hamilton Taylor
IQ397
Apr 25, 2017 | Snapper Garden
22' snapper walk behind mowewont start .cleaned spark plug and still wont start .swapped spark plugs from another mower that does work and the other mower starts with the snapper mower's spark plug .
You need several things for a running internal combustion engine:
  • Air
  • Spark (to start)
  • Fuel
  • Compression
  • Lubrication
  • Exhaust.
You've shown that you have a workable spark plug so far. Going from the above, consider as well
  • Fuel. Bad / old / contaminated fuel. Clogged fuel filter. If it's a motor that needs gas/oil mix, does your gas have the right oil mix?
  • Air: Dirty, clogged air filter or air inlet.
  • Spark. Is any electricity making it to that proven-workable spark plug?
  • Compression. For this one, the most likely problem (other than a toss-the-engine thing like a broken piston) would be if the spark plug is not tightened into the mount hole, allowing the air to leak out rather than compress.
  • Exhaust. Most lawn mowers will have a spark arrestor on the exhaust to make sure you don't set a dry yard on fire with your exhaust. It's often overlooked in diagnosing two-stroke engines. Make sure it's not clogged or blocked.
  • Lubrication. Is there oil of the right type, and up to a proper level on the dipstick. No oil equals way too much friction in the engine.
Good Luck!
DH
Apr 25, 2016 | Snapper Garden
Oil for a snapper snowblower 16223
I found the manual for you snowblower, and it's a two stage snowblower, so I am assuming you need two stage oil. Ultimately you need to get that information from the engine manual, and you haven't provided the engine information in you posting. This is the link for the blower manual:
http://dl.owneriq.net/1/121253fa-ec8b-4e20-b0b5-265321e0c7bf.pdf
Mar 01, 2014 | Snapper Garden
How to add oil to snapper lawn mower
if there is no dip stick then look about a inch above the base of the engine for a plastic screw about 1/2'' in dia
May 27, 2012 | Snapper Garden
May 14, 2012 | Garden
What 2-stroke mix for a Snapper mower (Briggs & Stratton 6.5 HP)?
USE A 32:1 MIX. THE MORE THE RATIO OIL TO GAS MIX RATIO THE MORE COOLER AND LONGER LASTING THE ENGINE WILL BE. 40:1 IS FOR FULL OUT TROTTLE CHAIN SAWS ECT.
Mar 13, 2012 | Snapper Garden
Tecumseh engine 10 hp what oil type
If this is for a snowblower and it is less than 40 degrees F 5W30 or 0W30 if full synthetic
Sep 18, 2010 | Snapper Large Frame 2 Stage Service Manual
Aug 30, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
