What does PF mean on my air con - Heating & Cooling
2 Suggested Answers
  • 767 Answers
SOURCE: Hi I DeLonghi T130ARC model
Hello my name is Heath it wil be my pleasure to assist you. The PF usually means there was a power failure and the only thing you can do is turn the power off to the unit unplugg the unit and let it sit for 15-20 minutes and then repower the unit and see if the pf goes away.
Posted on Aug 02, 2010
My front panel is blinking pf and won't blow out air
Pf means power failure try unplugging and replugging it and see if that works good luck
Jul 09, 2015 | Cars & Trucks
What does PF code mean on Amana PTAC unit?
I would assume that there was a recent Power Failure (PF) or that it may still have a power failure. Find the double pole breaker and turn it off and back on
Dec 05, 2013 | GE Zoneline AZ38H12DAD Split System Air...
My TCL portable air con display panel show'PF' and it can not start.
PF power failure. Please check input has right voltage. If so, check fuse in PCB.
Oct 16, 2011 | Heating & Cooling
My TCL TAC-12CPA air con display panel show "PF" and it would not be able to start.
PF-Power failure in pcb board. Check power to indoor unit and then to PCB. If no power, repair your PCB>
Jan 02, 2011 | Heating & Cooling
I have a pf code flashong on my a/c unit. Could you tell me what it means. I have the PAC l90
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Sep 24, 2010 | DeLonghi PAC L90 Portable Air Conditioner
Show me where the filter is located
dear sir /madam
please know what is type your air-con i mean widow type or split type or Central air conditioning's unit .if your air con is window type air conditioner then remove cover (grill) and find there is air filter if your air con split type of then open its cover there down side of cover there.is filter located
if air con is central cooling unit the find out your filter in duct side i mean air blower side where fresh cool air going to your room .
use this method i hope you will find solution of your problems
thank you
please vote!
Sep 06, 2010 | Heating & Cooling
Hi I DeLonghi T130ARC model air con and no remote and getting a messgae of PF error does anyone know what this means Andrew
Aug 02, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Dish washer displays pf code
PF is probably PE like mine, sometimes the bottome row of the liquid display doesn't work properly
PE is a Pressure Error - condition - The water level in Tub goes down during operation
Possible Causes
¥ The Circuit of Pressure Switch
shorted or disconnected.
¥ Pressure Switch is troubled or
disconnected
¥ The Controller is troubled.
¥ The Air Tube is kinked or damaged.
Possible solutions
¥ Repair or replace the Circuit of
Pressure Switch.
¥ Replace the Pressure Switch.
¥ Repair or replace the Controller.
¥ Remove the cause of kink or replace
the Air Tube.
Jul 18, 2009 | LG Dishwashers
Help On Your Fix Please
The instruction manual says that "PF" means "Probe Failure", that the probe is damaged.  The solution in the manual says to contact the service centre.
Customer Service:  800-322-3848  US Customer Service: 888-335-6644 Canada
May 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
