Question about Sta Rite 1 Hp Above Ground Pump Ne641
220v wiring diagram
Pump is clicking when turned on
CAN I WIRE THIS PUMP TO RUN OFF 110 OR DOES IT ONLY USE 220
There should be a wiring diagram on the side of the motor. It will show wiring for 220V,or 110V, or both.
Jun 22, 2015 | Pool & Spa
I have a 220V circuit (1 black wire, 1 white wire, and one green ground wire. The new stark industries pool pump has three terminals plus a ground, There is one terminal for a black wire (terminal A) and...
First, be absolutely sure that your motor is wired for 220v. If it is 110v and you apply 220v the motor will die instantly (after a loud bang). Also verify that your supply is in fact 220v.
Without exception 220v power should be supplied by two wires of the same color, as they are both "hot". Black and white wires are common in 110v wiring, the black being hot and the white neutral.
Every pool pump I have worked on has had two terminals where the wires attach to the motor, L1 and L2, wire orientation does not matter.
Evidently yours only has one. Apparently there is no wiring diagram on the side of the motor either, which is also atypical. Best bet is to call the factory for assistance with this.
Dec 22, 2013 | Pool & Spa
How to wire it from 110v to 220v...
Most pumps have the eiting diagam on the outer motor housing. What brand is the pump? Some motors have a jumper that is moved over to 220v or 110v post and the red/black(220) or white/black(110) stay on the regular screw terminals. Ground stays on the same terminal usually a green screw
Jul 21, 2013 | Utilitech 1-HP Lawn Pump UTP10P1
How to wire motor sta rite p2ra5e 181L
The green wire is the ground and bolts onto the motor frame on the top part,(should see a green screw). the other two wires go to the two posts with screws to clamp down on the wires. It does not matter which way these two are hooked up, one on each post.
Most motors are pre-wired for 220v from the factory. If you have 220v you're good to go. If you happen to have a 115v setup the motor will run at half speed. The motor can be converted to 115v by moving a brown wire and a white wire in the motor. The diagram is on the motor label.Best to verify your voltage first.
Mar 21, 2013 | Sta Rite Sta - Rite 1hp Dura - Glas...
Wiring diagram for aosmith a48a93a66 motor
Label will show wiring diagram.
Usually: L1 Line 1 will be 120V Hot
L2 Line 2 is Neutral
Low voltage is 115 volts
High voltage is 220 volts
Motor shipped new with 220V default
Compare existing wiring to what appears on label.
Label will show wire colors Brown, yellow, red, white etc.
Move these wires as needed to change voltage.
Take photo of label, post on internet, add comment with link to photo so diagram can be viewed.
Nov 08, 2012 | Pool & Spa
Does the pump come with the wiring set up for high voltage? I am referring to the brown and white internal wires. Pentair Challenger 346206. thank you
If you look at the wiring diagram on the motor plate it will show you where these wires go for 220v power, and where they go for 110v Power. If you know the supply voltage just place these wires as shown on the diagram and you should be fine.
Sep 17, 2011 | Pentair Challenger High Pressure Pool Pump...
Im hooking my pool pump up to a 220 and I dont know what wires go where. On the motor there is a A and B and a L1 and L2. What do I put my brown wire on and what does the white one go on. Can u help me...
There should be a diagram on the side of the motor showing you where to put the brown and white for 110/220 volt operation. Most new motors of this size are shipped strapped for 220v. The two hot wires will go to L1 and L2 and it doesn't matter which wire goes to which lug. For 220v you will usually have 2 black or 2 red wires and a green ground wire. If it is 110v supply, you will usually have a white and a black wire, and a green for ground. Hope this helps. Since you said you are hooking to 220v the brown and white should be on the correct lugs if this is a new motor.
Jul 19, 2011 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
I have just bought a waterway 3/4 hp. Can you give instructions ( or Diagram ) for changing wiring in motor over to 110 V from 220 V. Thanks, Pat
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside for both the 110 or the 220V convertions.
Jun 03, 2011 | Waterway Champion 1 1/2 Hp 230v Energy...
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Sta Rite 1 Hp Above Ground Pump  Ne641 Logo
50 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
