Question about Necchi 3537 Mechanical Sewing Machine
Manual Got it at Church yard sale -- no manual. Top post accepts bobbin -- where does the spool of thread go?
  • jasiu Aug 30, 2007
    I find there are 2 short knurled posts that you can pull up to mount a spool on. Clever disguise.
There should be another post 2 inches directly behind the bobbin threader post. I tried to move the front post to the back, but they do not seem to remove, so I'm surprised yours doesn't have the back one. Does it look like there is an empty hole for a post? Have you tried threading it with the spool on the front (only one in your case :) ) post? I have the same model # 3537
Posted on Aug 30, 2007
SOURCE:
How to wind bobbin on model 4411
Do you mean the Singer 4411 Heavy Duty sewing machine? If so,
first place the spool on the spool pin with an appropriate sized spool holder, if you are starting the project. Snap the thread into the thread guide to the left of the of the spool pin. Wrap the thread clockwise around the bobbin winder tension discs (slightly to the left and forward of the thread guide). Bring thread towards the bobbin spindle. Thread the bobbin (put the thread through the hole in the bobbin). Place the bobbin on the spindle with the hole up. Move the bobbin spindle to the right. Hold onto the thread above the bobbin and step on the foot control pedal. When the bobbin finishes winding the thread, cut the thread at the top of the bobbin and the incoming thread from the spool. Move the bobbin spindle to the left and remove the bobbin. If you have already threaded the machine for sewing, you will need to remove it from the various guides and tension discs that are used in sewing. Then after winding the bobbin, re-thread the top thread.
The directions to wind the bobbin are in the manual on page 12 (page 19 of the PDF). You can find many Singer manuals at the Singer support page: https://www.singer.com/support . The 4411 support page is https://www.singer.com/search/support?lp=support&title=4411 . The current link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%204411%20Heavy%20Duty%20Sewing%20Machine.pdf .
I hope this helps.
Apr 30, 2018 | Sewing Machines
How to fill bobbin
All machines are different, but basically it is done on the top of the machine. First you disengage the drive to the needle by slackening off the wheel in the centre of the manual drive (the big knob on the end of the machine for manually moving the needle). The bobbin and the threads spool go on spigots on top of the machine with the thread threaded past a roller. You put the thread into the bobbin and operate the foot pedal and the bobbin fills.
Most of the instruction manuals are online.
Google
make model manual
Dec 04, 2016 | Sewing Machines
Bought machine at a garage sale. It works but no Manuel of instructions. Need to know how to thread it.
If you can't download the manual, try putting the thread on the spool holder with the thread coming off the spool toward the back of the machine. Be sure your fly wheel is turned toward you until the need is in its highest position. With the end of the thread, work your way across the top of the machine to the left, staying toward the back of the machine, threading through any thread guides as you go. There may only be one. Bring the thread toward the front of the machine and through the thread guide at the top front of the machine, then down on the right side of the tension knob and back up to the needle carrier. Then pull the thread down through any thread guides until you get to the needle. Thread the needle and pull the tail of thread to the back of your machine. Load your bobbin into the bobbin case, insert the case into the machine until you hear a click (you may need to rotate the case slightly to get it into the machine.) turn your fly wheel toward you while holding that top thread toward the back of the machine until the bobbin thread comes up. Pull the bobbin thread up and to the back of the machine an you are ready to go! Good luck!
Jul 22, 2014 | Sewing Machines
Thread a bobbin on a 5825c
If you mean the Singer 5285C, the manual is available from Singer here: http://www.singerco.com/uploads/download/449_5_6_8_10_slide.pdf . The diagram for winding the bobbin is on page 14 and inserting the bobbin is on page 15.
I'll attempt to walk through the steps. Push in on the indent on the hand wheel to lock the needle in the current position (note rotate the needle up first). Then with a spool on the spool pin and the cap securely holding the spool on the pin, snap the thread through the thread guide post (near the center back of the top of the machine). Then wind the thread clockwise through the bobbin tension guide (towards the center front of the top of the machine). Next run the thread through the hole in the bobbin (inside to outside). Place the bobbin on the bobbin spindle on the front of the machine near the right hand side of the machine. Hold onto the thread end at the bobbin and start pushing down of the foot controller. Fill the bobbin to the amount of thread that you need, or until it stops. Cut the thread going from the spool to the bobbin.. Remove the bobbin from the spindle and trim the thread end that is sticking through the hole in the bobbin. Press the hand wheel disc on the side opposite from the indent.
Inserting the bobbin requires you to lift the presser foot and have the needle in the highest position. Slide open the face plate and remove the empty or wrong color bobbin. With the hole in the bobbin up, pull about 4" of thread off the bobbin. Place the bobbin in the bobbin case and hold it down lightly with a finger. Guide the thread through the notch near the front of the bobbin case. Then lead the thread down into the slot on the left and then around the second notch. The thread should be heading towards the center of the bobbin (left to right). Pull the thread diagonally back to the back of the machine and slide the bobbin cover closed. The thread should be coming up through the opening between the cover and the needle faceplate. To pull up the bobbin thread, thread the needle and then hold onto this top thread. Rotate the hand-wheel towards you until the needle rises above the needle plate. Gently tug on the top thread to bring up the loop of thread. Separate the needle thread from the bobbin thread with your fingers. Bring the top thread through the left side opening in the presser foot and then pull both threads to the back of the machine.
I hope this helps.
May 24, 2013 | Sewing Machines
I inherited my mother's Elna Lotus SP sewing machine. She had the sewing guide inside the machine, but not the instruction manual. I need to know how about the bobbin and how to thread?
Hi Jeanne, you might want to check out my tip on early Swiss Elnas,
http://www.fixya.com/support/r10602655-acquired_early_swiss_elna_sewing
it should help you get the Lotus going. Lovely machine. If you are in the USA you may also want to contact White Sewing Center as he may have this manual available for sale or a copy of it. www.whitesewingcenter.com.
Remember to use the Elna 7 hole dished metal bobbins, there are 7 holes on the top, and looks like this11_7_2011_6_23_57_am.jpg
Always wind it and insert it into the machine this way. Don't use any other bobbin. Standard needles 130/705H, flat shank to the back.
Check out my other tip on bobbin winding too, it is important to keep tension onto the thread spool that you are winding thread off as the machine doesn't tension the thread for you. So you need to apply pressure to the top of the thread spool as you wind off, use the curved handle of your scissors on the top of the spool.
Feel free to connect to me and ask if you have any other questions, I have a Lotus TSP at home and its almost identical to the SP. Happy stitching.
Oct 30, 2011 | Elna 2007 Mechanical Sewing Machine
The tension on the bobbin is giving big loops and then breaking
This could be one of the following:
  • wrong bobbin for the machine
  • bobbin loaded the wrong way - must rotate anticlockwise when you pull the thread
  • thread not into the tension spring/device on the bobbin holder correctly
  • bobbin wound badly, uneven tension, loose or uneven across the bobbin
  • poor quality or old dry brittle thread could cause the breaking (but the loops is definitely tension issues).
This is a top loading bobbin machine machine and you can download a manual from
http://www.singerco.com/accessories/manuals.html
Here is the threading diagram from the manual.
tally_girl_21.jpg It is important to click the thread down into the tension spring on all top loading bobbin machines and then pull gently on the thread to check that it is under tension, you should feel firm resistance when you pull the thread. If not, then take it out, and try again.
Other thing to look at is how the bobbin is wound. It is necessary to wind a bobbin smoothly and with some tension on the spool as the thread comes off it. Best analogy is the garden hose reel. If you wind it up and don't control where the hose goes onto the reel it will all lump up in the middle, and you won't get all the hose onto it. And then when you go to pull the hose out, it will jam and be difficult to pull. Same with bobbin thread. You want a nice neat even fill across the whole width of the bobbin, not just the middle. To achieve this make sure you use the bobbin winder tension disc when winding. Also use the spool cap on top of the thread spool to stop it from bouncing around as it unwinds - the thread will then wind off around the spool cap and this keeps it running smoothly and not twisting and jerking. If you don't have a spool cap then put the curved handle of a pair of scissors on top of the thread spool to tension it while you wind the bobbin. Also watch the bobbin as it winds, give the thread a nudge with your finger to control the fill onto the bobbin so it winds top, bottom and middle of the bobbin evenly.
I would suggest the following:
clean out the race following the manual directions to remove the bobbin holder, clean in this area, replace it. Wind a fresh bobbin and then load it into the machine, following the manual instructions carefully. Also thread the top of the machine following the manual, put in a new sharp needle from the pack, turn the top tension dial to a medium number (often 5 if dial goes from zero to 10).
Now test sew again. Look at the seam, if you have loops on the bottom of the fabric, underside, then the top thread tension is too loose or not in the top tension discs fully. Generally you should not need to adjust the tension on the bobbin thread for these machines.
Apr 13, 2011 | Singer 5050 Mechanical Sewing Machine
HOW TO THREAD THE BOBBIN
Take the thread-end from the thread spool to the left, around the bottom of the "silver" "button"; across the top of the button and back to the right to the bobbin winder.
Run the thread-end through a hole in the side of the bobbin spool, hold onto the thread (pull through about 5" of thread) and place the bobbin spool onto the the bobbin winding pin.
You may have to turn a bit to the left or right to get the spool in place. Push the bobbin spool to the right; against the bobbin winding wheel.
Press on the power pedal - keeping hold of the thread-end.
As the bobbin fills, the thead end will twist.
When you can not longer hold on. Stop the machine and clip the thread end then continue to wind the bobbin.
You can view and download a manual here (free) - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL2230
Mar 25, 2010 | Brother XL-2230 Mechanical Sewing Machine
My prdect is fashionaire 2380.when i'm sew somthing it's break the thread,and it's stack
Check the thread spool to see if there is a nick where the thread is catching. If there is, you can smooth away the nick with an emery board, or just flip the spool so the thread is feeding from the bottom of the spool.
Sometimes the thread feeds too quickly from the spool and puddles around the spool pin. A thread net (can be purchased online or at a sewing machine dealer) can eliminate this.
Check the threading to be sure it is correct - always thread to top thread with the presser foot up.
Check the bobbin to be sure the thread is feeding from the bobbin spool in the correct direction and through the correct guides.
Refer to your manual for threading and bobbin position.
Feb 20, 2010 | White Sewing Fashionaire Sewing 2380...
I was given an Elna Supermatic 722010 and am not sure how to wind the bobbin.
A link to a supermatic manual is here
http://www.arizonaexpressionz.com/elna_instruction_manuals/Supermatic.pdf - I suggest you download this and print it out as this machine is over 50 years old now and manuals are scarce.
Disengage the clutch by holding the outside of the fly wheel and turning the inner knob of the wheel towards you.
You need to take the thread from the spool across to an eyelet on top left, then back to the bobbin winder, up through a hole in the top of the bobbin and hold the thread tail. Flick the bobbin across against the stopper. Now press the presser foot or knee control to start the motor. Hold the thread tail until youve got coverage across the bobbin enough to hold the start, then stop winding and cut the thread tail with scissors. Now continue winding but put the handle of your scissors on top of the thread spool to stop it bouncing and ensure your thread winds smoothly and under tension.
Watch the bobbin fill and give the thread a nudge to fill top and bottom as well as the middle evenly, you want a nice even wind. Fill to 3/4 and stop, flick bobbin back off the stopper, then cut the thread. Remember to re-engage the clutch by reversing the first step.
This is a lovely heirloom Elna machine - you need to thread the bobbin as the manual describes and get the thread into the tension spring. Please read the manual information on oiling too, this machine needs to be oiled on the red spot locations every time you use it according to the manual, use good quality clear sewing machine oil for this purpose.
Oct 21, 2009 | Elna 2007 Mechanical Sewing Machine
How do you thread the machine, top and bottom, please.
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Dec 10, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Necchi 3537 Mechanical Sewing Machine Logo
99 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
