Question about Kitchen Ranges
Mcclary kitchen heater no 9 - Kitchen Ranges
I have a McClary Charm A2746 wood stove.I wanted to know what year it is?
Kathy, There should be a certification plate on the stove some where, listing make, model, year of manufacture, etc., open doors/drawers etc. to see if tag is riveted on inside panel or frame. Check the attached links they may help determine the age of your stove, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
McClary Charm A2746 wood stove Google Search
Antique stoves for sale
Ernie Woodstoves Durham Ontario Canada Repairs Restoration Sales
Strong on Stoves
mcclary wood stove history Google Search
Jul 15, 2016 | Home
Where is the model number on a McClary fridge?
Hallo
There are 4 different places no matter which brand fridge it is it will always be one of these 4 but I'll put them in order from most fortunate to least fortunate location.(I'm sorry I don't know where McClary's product info tag is located but surely it will be one of these 4 places)
1) On the inside Left or Right wall of either the refrigerator or freezer.
2) Behind a lower crisper draw.
3) Behind the kick plate.
4) On the cabinet door jamb.
The tag should look something like in the photo I posted for you.
Regards.
Jun 10, 2016 | Refrigerators
Mcclary stove
One thermostat (sometimes at the back of the stove) is open/blown or the door locking assembly has failed. To open the door you may remove the back of the stove; take the door locking assembly apart to release the long wire that hooks the door close.
On some models you can see the locking the latching mechanism through a **** in the top front and can play with the mechanisms there to release the door.
Then you can begin to figure why the door latched in the first place.
Oct 20, 2013 | Kitchen Ranges
How to reattach door onto stove
pull the tips of the hinges down with a reg. pair of pliers until they stay in position. take the door and there should be a slot on each side where the hinge goes in. position 1 side and start it then teeter the door to start into the other slot. make sure it looks even on both sides then give a good push and the hinge guides should go all the way into the door and you are done...you might have to try a couple times. but, with these instructions you will get it good luck and let me know how you do goodday//
Nov 13, 2009 | Kitchen Ranges
McClary washing machine won't spin. A technician
washing machine fills up to much with water on med fill and not enough on min fill
Nov 03, 2009 | Washing Machines
Dryer does not dry
The suggestion from barnsleymick gave us some good direction in fixing our Kenmore SmartHeat Quiet Pak 9 HE 4. We discovered our vent pipe was clogged with a great deal of lent and a quart or two of water. We cleared the vent of the lent and water and the dryer is now working like a champ! Thanks for the direction.
Sep 18, 2007 | Kenmore Elite HE4 Electric Dryer
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
