Candy e07 It apear on a display after washing-e 07. It is a Candy GO W 496 D.
  • 25 Answers
SOURCE: Spin problem on Candy CN450 Washing Machine
nice
Posted on Dec 14, 2007
SOURCE: Candy washing machine C514 manual
my machine does not start the light works on the panel.
Posted on Oct 02, 2008
SOURCE: candy drum bearing replacement
Hello
This is fairly straightforward but little hard work to remove and fix. If you have Candy Washing machine such as model CE430 which is fully automatic electro-mechanical with AC motor , the replacement will be as follows that I have done successfully
1. Remove the belt and motor, then remove the hex nut on then drum pulley. But pulley may not come out. It is suggested to remove the hex nut whiled drum on the frame because it is easy to remove while it is on the frame.
2. Take the complete drum assembly out of the washing machine frame.
3. Leave the drum assy on a bench with pulley side upward, use puncher to tap onto the center of the drum spindle, make sure that you will not damage the screw threads on the spindle. the spindle should go down the pulley should pop up.
4. Then keep punching until drum spindle and the “Y” arm assemble comes out.
5. Now you will have the pulley and drum and Y spindle removed. the 2 bearings and water seal still in the drum casing.
6. Use rust cleaner chemical or spray to dissolve the rust off. Then use either bearing puller or use iron puncher to tap on the bearing gently but hard , may use 1kg hammer and take each bearing out. The inner bearing will come out with the water seal.
7. How to get the spare parts; these parts are very common in this geographical region ( Asia). You can buy generic parts. Get the mechanical specifications on the bearing to buy the bearing. The water seal which is generally referred as oil seal, look for specifications such as specs will have inner & outer diameter and the height ( width) ie 22 mm, 40mm and 10mm for water seal of the Candy CE430. Make sure you have the exact shape of the water seal as the original one.
8. Install back the new parts: you need to smoothen the spindle and clean the area as well. to have less friction , smoothen the spindle surface using sand-paper, it will be easy to press the bearing and the spindles.
9. 1st you install the bearings. You need to add thick lubricant in between the inner bearing and inside of the water seal. Then insert the water seal as well.
10. The drum spindle can be inserted to the bearing, you cannot use iron hammer because it will dent the drum, you need to push and may use wooden plank warp with thick cloth like towel to batter on to the center of the drum gently, if the spindle is smoothen properly it should go in with out a hassle. Make sure that drum rotates freely, then pulley can be installed.
11. The drum bearing replacement is completed
12. Re-install the other parts back.
Pub
Posted on Nov 18, 2008
sodeep
  • 3267 Answers
SOURCE: Hi i have candy go washing machine it shows error
E05 indicates that the pressure switch is stuck on full, this may be that your pump is jammed or blocked. Remove the filter and clean it out, also try to fish around in the tube that leads up to the drum. If this doe snot remedy the fault have it repaired by an engineer or someone whom has a rudimentary understanding of the mechanics of a washing machine.
Posted on Jan 08, 2011
ginko
  • 19396 Answers
SOURCE: Error code E08 on candy washing machine
Hi.
E08 means that the motor has failed (tachiometer error). Shut down your machine and disconnect power cord for five or ten minutes. If that is not enough to clear the code call the support number listed in your owner manual.
Regards.
Ginko
Posted on Dec 15, 2011
Who is the dealer of candy washing machine in Sri lanka
you might find something useful by visiting the following website
http://www.beltconveyers.net/crushing-plant/agent-for-candy-washing-maching-in-sri-lanka.html
or this one which seems very similar:
http://www.chinagrindingmill.net/grinding-machine/candy-washing-machine-sri-lanka-agent/
but I am not hopeful. You may find it better to contact a European site such as
http://www.candy-domestic.co.uk/products/?catid=1
and asking your question of them.
24.August.2014
Aug 24, 2014 | Candy Washing Machines
Not spinning displays e03
hi i have a candy washing machine and it wont turn on with the mains i have tried everthing and it wont come on at all anyone to help me please email me at paul.barnett2@live.co.uk thanks
Dec 03, 2013 | Candy CNW136 Front Load Washer/Dryer
My washing machine is in a working condition but why the clothers are not properly wash and some kind of brown or black stain apeared. Even when white clothes are separetly washed. Is there any help can...
this could be Drum bearings gone if its oil in clothes, Is it very noisy during spin if so then Bearings, quite an expensive repair......Not always worthwhile...
May 03, 2011 | Candy Washing Machines
Could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
Dec 10, 2009 | Candy Washing Machines
Where can you get a circuit board for a candy cn450 washing machine?
I can supply you with a circuit PCB Board for the candy CN450 washing Machine it is £69.50 + P&P £5.95 if you require one you can order from our shop in Market Drayton Appliance World 01630655965
Nov 09, 2009 | Candy Washing Machines
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
