Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
Replace the applicable ink cartridge and close the cover.
Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
The ink cartridge has not been installed correctly.
Resolution:
Lift the printer cover up.
Check that the red lights on the ink cartridges are all turned on.
If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
Error Condition
Indicator
Beeps
Error Code
Possible Solution
Paper Feed / Delivery
Orange
Remove any paper jammed
Paper Jam
Orange
Ink Out
Orange
Add Ink
BJ Cartridge Misinstalled
Orange
5
Re-install cartridge or replace it
NO BJ Cartridge
Orange
6
BJ Cartridge Error
Orange
7
Waste Full warning
Orange
8
Waste is almost full , needs service very soon
Service ErrorsBlinksBeepsError CodePossible Solution
ROM Error
1 x Orange
10
6100
Try unplugging Printer
RAM Error
2 x Orange
10
6300
EEPROM
3 x Orange
10
6800
Home Position
4 x Orange
10
5100
Temperature Sensor
5 x Orange
10
5400
Waste Full
6 x Orange
10
5B00
Needs Service
Cartridge OverHeat
7 x Orange
10
5200
Replace the BJ Cartridge(Printhead)
Cartridge OverHeat
8 x Orange
10
5200
Cartridge Displaced
9 x Orange
10
5200
Replace the BJ Cartridge(Printhead) or reinstall
Cartridge Displaced
10 x Orange
10
5200
Cartridge Displaced
11 x Orange
10
5200
Other Hardware error
12 x Orange
10
6500
None
None
5910
Needs Service
None
None
5C00
Needs Service
How to clear Error Code Canon printers MP150 MP160 CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF) E3-3 Paper jam E4 No ink E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD overcurrent error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) 4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.) The number of the Reset button pressing LED Function Remarks
0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset See waste ink counter reset procedures below. 5 times Orange Destination setting See Destination setting procedures below. 6 times Green Print head deep cleaning 11 times Orange Button / LCD checking 12 or more times Returns to a menu selection If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
The Power Light Flashes Orange - Error Codes
When
an error occurs, the power light flashes orange. The number of orange
flashes followed by a long green flash indicates the cause of the
problem. Two orange flashes:Out of paper, paper jam, or paper feed error
If
no paper is loaded in the auto sheet feeder, or if the paper is not
loaded correctly, set the paper correctly and press the Resume button
on the printer to continue printing. Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly
Remove
and reseat the cartridge correctly. Make sure the orange protective cap
and tape have been removed. Make sure the blue locking lever is locked
down securely. Six orange flashes: BJ cartridge (printhead) is not installed
Remove
down securely. Seven orange flashes: BJ cartridge (printhead) is defective
Remove
the BJ cartridge and check that the contacts on the cartridge and
cartridge holder are clean. Make sure the orange protective cap and
tape have been removed and reinstall the cartridge. If the error occurs
again after you resume operation, you may need to replace the BJ
cartridge. Eight orange flashes: Waste ink absorber almost full
The
printer has a built-in waste ink absorber to hold the ink that is
consumed during print head cleaning. This error indicates that the
waste ink absorber is nearly full. Press the Resume button to skip the
error so you can continue printing. The POWER light flashes orange and green alternately: Service error
A
service error means the printer requires the attention of a qualified
technician. Count the number of flashes. (You may be asked this
information.)
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160 CANNON Printers MP150/MP160 ERROR CODE E2-2 No paper (ASF) E3-3 Paper jam E4 No ink E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly E8 Waste ink absorber full, or platen waste ink absorber full
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting formenu selection) 4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.) The number of the Reset button pressing LED Function Remarks
installed properly E8 Waste ink absorber full, or platen waste ink absorber full E9
Direct
Printing
E22 Carriage error
error
rise error -
E29 EEPROM error
try this methode
Methode 1
the LED
button pressing
procedures below.
procedures below.
Direct
Printing
E22 Carriage error
error
rise error -
E29 EEPROM error
try this methode
Methode 1
the LED
button pressing
procedures below.
procedures below.
Direct
Printing
E22 Carriage error
error
rise error -
E29 EEPROM error
try this methode
Methode 1
the LED
button pressing
procedures below.
procedures below.
Direct
Printing
E22 Carriage error
error
rise error -
E29 EEPROM error
try this methode
Methode 1
the LED
button pressing
procedures below.
procedures below.
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see?
At any rate here is the code:
Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician.
If you have any more questions let us know otherwise please don't forget to rate this post.
my printer is showing error code 3806
it says II have error codee 3806 and can not change that status
error code 3806
