Question about HotBrick SoHo LB-2 (LB2) Firewall
Hot Brick LB-2 Router....
How can I implement port forwarding on this router?
  • 196 Answers
The manual is here: I believe you need the "Special Applications" screen on page 36.
Posted on Aug 30, 2007
Port forwarding on Linksys SRW224G4P
Google took me straight to the manual. This is a Switch not a router so it operates in layer-2 (ethernet). Layer-2 ports are the interfaces on the back of the switch. You want a router that can do layer-3 TCP/IP port forwarding. Layer-3 ports are unsigned 16-bit integers associated with an IP address and a protocol.
Oct 13, 2013 | Linksys SRW224G4P 24-Port Ethernet Switch
Port forwarding
Connect your Internet phone directly to the cable modem and see if you can use Internet phone directly through the modem.
If it works through the modem then it must be the issue with the port forwarding.
First get the port numbers from the phone manufacturer.
Open the setup page of the router and open those port numbers.
Jan 15, 2012 | Linksys Wireless-G WRT54G Router
I need to open a port from my router
Navigate to "My Network Places" on your computer. Right-click on the LAN with which you connect to the Internet.Select "Properties" from the drop-down list.Click the "Advanced" button, and highlight your connection. Then, click on "Settings." A window will open showing the ports that you currently have set up.Click on the "Add" button to make a new port. Put the desired IP in the Name or IP Address box. Put the port number in the fields below it. Also, you probably will want to select "TCP," as it is the newest technology with the most services and compatibility
Creating Ports in Your Router
Access your router by opening your web browser and typing Type your router administrative user name and password when the login box opens. Once you type this, the routers settings should open on the screen Navigate to the applications tab of the settings window and select port forwarding. This should open a screen full of port range boxes. Fill these with the same settings you used on your LAN connection and click "Save Settings.
Restart your system to implement the changes you have made.
Dec 30, 2010 | Computers & Internet
NetGear WGR826V has no clear port forwarding section in the setup, the mamnual is as clear as brick as to how do I forward a port on this brain dead router?
Forwarding Port – If you select 'Same as Incoming port' then all incoming traffic on specified Service is forwarded to LAN server without modifying Destination Port. – If you select 'Forward to another port range' then all incoming traffic received on the Service port (or range of ports) is forwarded to this port or range of ports of the LAN Server. – This field is disabled if action selected is "Block Always". – If you want to forward the traffic to a single port then enter port value in start port and leave finish port empty. – If you want to forward the traffic to range of ports then enter non zero value in finish port and make sure that service record attached to this rule has range of ports and range is equal to that of forwarding ports. – For example if you select Service as HTTP (TCP/80), LAN Server IP address as and Forwarding port as 8080 then all traffic coming from internet on – TCP/80 (HTTP) to this Router is redirected to TCP/8080 port of • WAN Users: These settings determine which packets are covered by the firewall rule, based on their source (WAN) IP address. Select the desired option: – Any All IP addresses are covered by this firewall rule. – Address range If this option is selected, you must enter the "Start" and "Finish" fields. – Single address Enter the required address in the "Start" fields. • Log: This determines whether packets covered by this firewall rule are logged. Select the desired action. – Never - never log traffic considered by this firewall rule, whether it matches or not. – Match - Log traffic only it matches this firewall rule. (The action is determined by this firewall rule.)
Ok well this is out of the manual, to me it seems straight forwards, but it is a brick too though, there is an example to help you, basically you tell it the Address of the PC, (Right click on NIC and get address) that you want ports to go to.. then ALLOW it, UN-disable actually.. in the tables.
Feb 05, 2010 | NetGear WGR826V Router (wgr826vna)
I cant get ny linksys router to work for my computer and my xbox at the same time?
There may be a place in the router panel just for the xbox, there is in mine. Also, you may need to forward some ports for that. I flashed my router with DDWRT, and that router panel is awsum. If you decide to flash the router with DDWRT, be VERY careful, follow the instructions to the T. If you brick the router you're screwed.
Dec 02, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
How to forward port on telkom mega 100wr router
You have two options:
1. You can open port using router's web interface. Check what ports used your software, what protocol TCP/UDP/BOTH then go to web interface's virtual server and add new user's rule. Then you have to save and reboot router. Every time your PC IP changed (static IP recommended) or program you using changed port number you have to do web interface operation again.
2. Download and install Router Commander (fully compatible with your router) and that's all. The software will forward ports automatically
Nov 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Dose this router work as a firewall switch?
It is not possible to close all the ports on the router.
you can open other ports.
by default port 80 is open on the router.
On the router there is no such setting to close the port.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
I need to open a port to use utorrent
first u download a software called ultra surf from anywhere on the net...then this software will search for most suitable port and it will open it for u...
simply u can change the port no. between ' 6880-6889 ' in the preference option in utorrent....I think this will solve ur prob...KSHITIJ
Jun 17, 2009 | D-Link GamerLounge DGL-4300 Router...
HotBrick SoHo LB-2 (LB2) Firewall Logo
226 people viewed this question
Top HotBrick Computers & Internet Experts
David Payne
David Payne
Are you a HotBrick Computer and Internet Expert? Answer questions, earn points and help others
